Question about Hydrofarm Tomato Barrel Planter With 4 Tower GCTB
Instructions to use barrel
I am not sure the steps to put components together add soil and plant there aren't any instructions
What are the easy and best ways to take care of flower garden?
1. Keep the water up to them so they do not dry out completely but do not over water. Many species of flowers will die quickly if allowed to dry out, especially in hot summers. Get yourself a good book covering the species of plants you have to improve you knowledge in caring for the plants.
2. Fertilise with a suitable slow release fertiliser in spring and summer.
3. Mulch the beds with a suitable product to retard weeds and retain soil moisture.
4. If the flowers are planted in a heavy soil dig a little river sand into the soil where possible in existing beds.
5. Don't use garden chemicals to ward off pests. If you have pest susceptible flower species that will require chemical spraying and the like, remove them and replace them with hardier more resilient species.
Feb 29, 2016 | Garden
How do we strike lavender from a cutting
Take a look at the video and the Wiki how step by step
hope this helps you http://www.wikihow.com/Strike-a-Lavender-Cutting
Feb 24, 2015 | Garden
How to kill poison ivy,sumaca, poison plants outside your house?
Ortho Brush-B-Gone is quite effective, but it may harm other nearby plants, so take proper care. Make sure you follow the instructions on the container, and wear protective clothing. Do not apply on windy days, and it's best to check the weather forecast to make sure rain doesn't wash it off before 24 hours has passed. Once the plants are dead, again put on protective clothing, eye protection, and a heavy dust mask over your nose and mouth, so you won't become affected by the toxicity of the plants. Remove the plants and place in a large plastic bag. (do not burn them, it will spread the poisons through the air) Then dispose of them in a proper manner. When you're done, remove your protective clothing OUTSIDE, so you don't transfer the toxins to your furniture or carpeting in the house.
Aug 12, 2014 | Garden
Information about clematis plant.
Clematis is a wonderful flowering vine that is known to many
in the gardening world as the "Queen of the Climbers".
While clematis takes a few years to establish a strong root
base before it hits it\'s stride in the blooming department, it is definitely worth
the wait.
This plant climbs up to 12 feet high and spreads 3 to 4 feet
wide.
If planting more than one follow the steps below spacing the
plants 3 to 4 feet apart.
In the spring or early summer, dig a hole one foot deep and one foot wide.
Mix the soil from the hole with compost, working it until it maintains a loose
rich texture.
Ideally this should leave you with a very dark soil.
Create a mound in the bottom of the hole using the
enriched soil.
Place the plant above the mound and allow the roots to trail
over the mound.
Cover the roots and fill in the hole with the enriched
soil, keeping the crown of the plant about 2 inches below the soil level.
This plant likes shade on the bottom and sun on the top.
Water at planting and regularly for the first season,( I
prefer to water in the morning or evening and do so every other day.) after
that you should only need to water in extreme dryness and drought.
Install a piece of trellis or fencing behind the Clematis
to give it support as it grows and a foothold for climbing.
To promote blooming and keep your Clematis healthy, prune
as needed after the blooming season, and in preparation for the blooming season
prune in late March each year.
Aug 08, 2013 | Computers & Internet
Is compost good for land?
Compost is good for land and can be used to condition soil, to fertilize soil, to add humic acids, or as a soil pesticide. In an ecosystem, it can be used to control erosion, to construct wetlands, to cover landfills, etc.
Jan 30, 2013 | Garden
I need instructions for the Davinci Christie Crib
Unfortunately, we do not have these instructions, as of yet, but I came across a eHow guide on putting this crib together. I hope this helps.
http://www.ehow.com/how_7168944_assemble-christie-convertible-crib.html
Oct 28, 2011 | Baby Gear
Please give instructions - dilution rates for Roundup Amenity 5L . This would be for a small garden
For 5L of water 50ml of roundup can be used. Remember Roundup works by being absorbed by leaves not through the soil so spray in calm weather and shield your plants with a bit of cardboard or plastic if you need to get really close.
Apr 03, 2011 | Roundup "" Weed & Grass Killer
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from service@bhsciencetech.com
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 | Toys
Hydrofarm Tomato Barrel Planter With 4 Tower GCTB Logo
613 people viewed this question
Top Hydrofarm Garden Experts
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Angelo Monroe
Angelo Monroe
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
