Question about ALEKO Animal Trap 17"x5"x5" for Squirrels, Rabbits, Chipmunks and
How do you assemble & set up trap
Set up
Tip
Slow shower drain fix.
This tip will show you how to fix a slow tub drain. In my experience most slow shower and tub drains are caused by hair. Usually within reach of a wire hanger. Since you probably do not have all the proper tools, you must be careful not to damage your drain line.
The trickiest part with most shower drains, is the pop up assembly.Most times the hair is caught on the pop-up components. If you have a pop-up, check with your local hardware guy to show you how it works and is assembled. On a pop-up, you'll have to take the drain plug/cap off. have the cap in up position, and get your eyes below the cap rim, you will see a small set screw, a couple turns and cap should come off, do not take set screw all the way out. If you see hair on assembly after taking assembly out, remove the hair and run some water to see how your drain is working. If that does not fix your slow drain, you should stop there and call a plumber, because that means you blockage is further down the line then you'll be able to reach.
If you have no pop-up assembly. Untwist hanger, make as straight as possible, then with a pair of needle nose or any pliers you have, go about a half inch in from the hook side. Make a U bend, about the same size and shape of the end of a paper clip. Go in drain a inch and turn hanger in a circle trying to catch the hair blockage. Twist a couple times and pull back gently, do not push hanger in to far, you might break your pipe or the hanger may get caught in the p-trap or even worse drum-trap,(older houses tend to have drum-traps, I suggest not to even attempt to clear any blockage were a drum-trap is involved,call a plumber)
If its hair, you will see this black sludge looking hair ball that may make you sick. Don't worry you'll be happy when all is said and done, and you can shower without standing in your own filth. If its not hair, you probably have a more serious problem. Call a plumber and make sure your plumber gives free estimates.
Other Tips:
http://www.fixya.com/support/r5197305-stop_water_sweat_solder_water_line
http://www.fixya.com/support/r5238897-reset_toilet
http://www.fixya.com/support/r5245506-leaking_shut_off_valve_hard_close_shut 4d20c6a.gif
on Jul 01, 2010 | Plumbing
How do you set this trap
There will be a trigger mechanism on the side of the trap. When you raise the doors the trigger mechanism has two points where one will rest on the other holding the end doors open. I would recommend putting the bait on the trigger pan before you set the trap. When ever the animal touches the bait it causes the one arm to move in turn allowing the second arm to fall closing the doors trapping the animal.
Dec 04, 2013 | One Stop Gardens 32-1/2 L x 10 W x 13-1/4...
Need the final drive gear &flange set for a honda valkyrie 2001 interstate
Ebay is a wonderful thing. You may be able to obtain a whole fial drive for a real good price. Probably for way less than the parts.
Jun 04, 2012 | Motorcycles
I can't remove the glass trap in my frigidaire dishwasher 4ghd2433kf
Try http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/. They didn't have my exact model number so I looked it up by type and found something with enough model numbers matching that it was actually a good match for the manual as well. What worked for me: "To empty the glass trap: 1. Grasp the glass trap's handle and rotate it 900 clockwise while pressing down on the center of the wash arm. 2. Grab the spray arm in the center and lift the spray arm and glass trap assembly up and out from the dishwasher. 3. Tip the assembly over an appropriate container and tap it to empty the glass trap. OR, separate the glass trap - pull the glass trap handle toward you, then up, then further toward you to slide it away from the rest of the assembly; empty it into an appropriate container; then slide the glass trap back into the assembly. 4. Place the assembly back into position, press down on the arm at the center and rotate the glass trap handle 900 counterclockwise being sure the glass trap ends in the orientation shown in the image above. To avoid damage to your unit make sure the spray arm and glass trap are fully snapped in place."
Apr 29, 2012 | Frigidaire Dishwashers
How to set my wshing machine initialy?
If the laundry area already has all the set up, all you have to de is hook the washer's
Diagram of a washing machine to help you install a washing machine
drain hose over the sink's edge. If there is no sink nearby, the washer will need to drain into a standpipe. A drain pipe is basically a pipe with a diameter of 2 inches with a built-in trap that taps into the nearest drainpipe. The top of the standpipe should be between 18 to 42 inches above the trap. The trap should be about 6 to 20 inches above the floor. Standpipes are readily available with built-in traps or can be assembled using standard drainpipe and elbow fittings.
To prevent any unexpected and unwanted flood because of any leakage or bust f the hose pipe, you can use a single-lever valve in place of conventional washing machine shutoff valves. You can simply flip the liver to shut off when the washing machine is not in use.
  1. Screw the washing machine's water supply hoses onto the connections at the back of the washing machine. If the hoses are marked, orient them to hot and cold according to the markings.
  2. Connect the washing machine supply hoses to the right valves. Adjust the level of the machine.
  3. Put the drain hose into the standpipe or the laundry sink. Turn on the water supply valves, and check for leaks.
May 17, 2011 | Washing Machines
The washing machine will not drain. I cleaned out the pin trap where there was a coin and safety pin, but this has not solved the problem. The machine will spin when I turn the program knob to spin, but...
Hello & Welcome to FixYa
If you have already cleaned the drain filter assembly located inside the bottom front panel and the problem is not solved then it is the drain pump that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Asko W6661 Front Load Washer
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
Dec 23, 2010 | Sport & Outdoor - Others
Cleaning the trap
The soap trap and its cap covers the soap in your dishwasher after you fill it and then swings open to dispense the soap when the wash cycle starts. If your dishes aren't getting clean or you notice the soap trap door is still shut after the dishwasher finishes a load, it may indicate a problem with the soap trap you'll need to fix.
Instructions
Things You'll Need:
  • Dishwasher soap cap replacement,Screwdriver,Multimeter.
  1. 1 Open the lid of the soap trap and clean out any leftover soap. Soap and detergent, especially the inexpensive brands, can clump together and harden inside the soap trap instead of releasing into the water during the wash cycle. Change to a different soap and run the dishwasher again. See if the clumps disappear and if this solves the problem.
  2. 2 Remove the old dishwasher soap trap cap and replace with a new one. The plastic cap should slide or pop off. The instructions for the new cap should instruct you how to slide or pop it back into place. A new cap may solve the problem if the cap is not opening during use.
  3. 3 Turn off power to the dishwasher by either turning off power at the circuit breaker panel box or moving the unit out from the counter and disconnecting it from the power supply. Always do this when working inside the dishwasher to avoid electrocution.
  4. 4 Open the dishwasher door and remove the screws to take off the front paneling. Leave the screws holding the bottom hinges to the door in place to keep the door itself from falling off. Depending on your model, you may need to remove some clasps as well. Your goal is to gain access to the inside of the door and control panel so you can see the different knobs and buttons, and can fix the parts controlling the soap trap.
  5. 5 Locate your soap trap. Close the soap trap cap and insert a screwdriver to push on the metal piece -- called a bi-metal switch -- connected to the soap trap cap until the cap swings open. If the metal looks out of place and the cap doesn't swing open like it should, push the metal back into place with the screwdriver and try again. If this does not fix it, remove the metal piece and replace with a new one.
    If you can't find the metal piece, your dishwasher may use a wax motor assembly instead. Located near the soap trap cap, it's typically a small red or maroon colored plug with a small black rod sticking out of the end. Remove the wax motor for testing if you don't have a bi-metal switch.
  6. 6 Locate the round timer motor inside your dishwasher. Refer to your dishwasher's instruction manual for help identifying the different parts. Typically, the timer motor is a round piece with holes in it, and may be located near the timer control on the dishwasher itself. Remove the timer motor from the dishwasher.
  7. 7 Test the timer motor and wax motor assembly using a multimeter .Choose one of the motors to test and place one probe from the multimeter to one wire of the motor and the other probe to the other wire. For the timer motor, Part Select.com suggests setting the multimeter to the "x1000" ohms setting and you should get a reading of 2000 to 3500 ohms. If your reading is significantly different, the part is bad. For the wax motor assembly, set to the "x1" ohms setting and touch the probes to the wires. If the screen shows the infinity symbol, the motor is bad. Replace either part as needed.
HOPE THIS HELP?
Thanks.
Nov 06, 2010 | Dishwashers
ALEKO Animal Trap 17"x5"x5" for Squirrels, Rabbits, Chipmunks and Logo
224 people viewed this question
Top ALEKO Hunting Experts
Ned Halaweh
Ned Halaweh
Dan Apthorp
mark moore
mark moore
Level 1 Expert
Are you an ALEKO Hunting Expert? Answer questions, earn points and help others
