Question about Rotary Hilti Te50 Demolition Hammer Drill Chipper
Service light on
The service light is on. what needs to be done for service. how is the light reset
Reset the brake fluid in a 30xiBMW
Karen, the garage that did the fluid change should have done this for you, it is part of the service. Can not find your exact model, will post links to similar.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Instructions for Resetting Brake Fluid Service Indicator
DIY resetting service due lights
DIY 335 Service Light Reset
Jul 30, 2016 | Cars & Trucks
How do I reset slip indicator sensor? Light is still on..
take it back and have the service person reset the light
check that the service was actually done because any competent mechanic or shop would have cancelled the light on completion of the service
Jun 16, 2016 | Cars & Trucks
RED LIGHT INDICATING OIL SERVICE
Hi. The oil service light in red indicates that the vehicle is over due for a vehicle service..OIL SERVICE.. If you don't have it done, it could all go wrong. Have the light reset after Service and then it will monitor for your next service.bye for now.
Feb 19, 2014 | 2002 BMW 3 Series
I need to reset service light
You should be able to reset the service light by turning the key to the "run" position (do not start vehicle) and then immediately push down on the gas pedal to the floor 3 consecutive times and then start the vehicle... this should reset the service reminder light. when you push the gas pedal 3 times it must be done consecutively within about 15 - 20 seconds. Hope this helps...
Oct 22, 2012 | 2008 Chrysler Pt Cruiser
Recently had an oil change done. service engine light needs to be reset, don't know how to do it
You can try to disconnect your battery for about 5 minutes and that will usually reset the computer.
Sep 20, 2012 | 1999 Ford Taurus
How to turn the sevice warning light off after oil change ?
BMW Model E39 built from 1996~2000 will have a port like the one shown below. A Reset tool like a Peake R5 or R5-FCX is needed to reset the oil service or inspection service lights after required service.
1) If you have a reset tool then turn your car key to Position II but do not start the car.
2) Turn the cap counter clock wise on the Data Link Connector and insert the Reset Tool
3) Follow the instructions of your reset tool, different models may have different functions however they all create a short in PIN 7 to PIN 19 for a given amount of time.
  • OIL Service Reset requires pin 7 and 19 to be closed for 3+ seconds
  • INSPECTION Service Reset requires pin 7 and 19 to be closed for 10+ seconds
  • 4) Once done, remove the reset tool and close the cap .
    5) Your dash should light up with green lights at this point.
    If the light did NOT reset after the above steps then you might be resetting Oil Service however an Inspection Service is needed.
    Aug 04, 2010 | 1998 BMW 7 Series
    Had transmission service done few days ago... now light comes on... what could it be?
    With all the electronic components in newer vehicles, anytime major service is done the system computer module needs to be reset. Take the car back to whomever serviced the trans and have them do a reset.
    Jan 05, 2010 | 2003 Chevrolet Monte Carlo
    Reset the service milage for 330ci 2003
    Assuming this is a service level indicator and not Check Engine Light, instructions by bwwatson above are incorrect.
    Please note, I don't recommend resetting this unless you perform BMW's service recommendations first.
    After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button in while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
    Jun 25, 2009 | 2001 BMW 330
    Reset the service light on a vw touran 2005
    Look in owners manual you can do this yourself very easily using ignition,milage reset button and clock reset button it's in the book cant remember which page
    May 30, 2009 | 2005 Volkswagen Touareg
    BMW 5 series - 2005 model - resetting service & waring lights
    this needs to be done with a european capable scan tool,check around to see if someone has this tool, no other way sorry
    May 19, 2009 | 2007 BMW 530xi Sports Wagon
    Rotary Hilti Te50 Demolition  Hammer Drill Chipper Logo
    80 people viewed this question
    Top Rotary Hammering Experts
    John Trevino
    Steve
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Rotary Hammering Expert? Answer questions, earn points and help others
