Question about Duo Fast Air Tools & Compressors
I need Duo-Fast part #TST-AM0040AA
MY PART IS PLASTIC AND IT IS BROKEN
Df225 duo fast coil nailer shoots once and driver stays out as soon as i put air to it when i take air off it comes back down
Time for cleaning and replace o-rings (beware on the gaskets if neccesary don't forget to order if needed and a good basic lubrication because its not an oilless tool the o-rings need a regular pneumolube oil without oil or too lean lubrication its working short time but important the o-rings above the cylinder in that valve above the cilinder or an o-ring is worn or used without oil and broken or gotten hard by the build up heat use always the special oil nebulizer because the heat dissipating properties are very important for using oil.
The o-rings should all replaced and need by replace also another but a base lubrication sillicon grease or a good sillicon based sprays innotec sp200 or oks1110 grease and all o-ring parts before use from pos 6 - and with 20 Buy Duo Fast DF225C Coil Siding Nailer Nailer Parts
Jul 22, 2017 | Duo Fast Air Tools & Compressors
Can you replace the door sliders on the tst-28sd-d2 one of the guides broke
You should be able to find the part at this website. They have a full line of Turbo Air parts for commercial refrigerators.
https://www.kitchenstuff.com/turbo-air-greenworld.html
Sep 13, 2015 | Turbo Air TST-28SD-D2 Super Deluxe...
Can you source nails for a Hitachi VH 650 Coil Nailer
I am not positive but I believe the Duo-Fast CI series, plastic collated nails may work in your Hitachi. At least worth a try.
Feb 18, 2012 | Air Tools & Compressors
Repair duo fast nail gun
Duo-Fat is now owned by ITW which also owns Paslode. The DF350S is basically the same thing as the F-350S Paslode. Go to Duo-Fast's website to locate a servicing dealer nearest to you.
http://www.itwindfast.com/buy.cfm
Feb 16, 2012 | Duo Fast DuoFast DF350S 20? Round Head...
What degree nails should be used for a duo fast Cn 350 B nail gun?
The CN350 uses a 20 degree, full round head, plastic collated nails.
Jul 21, 2011 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have got a second hand Duo-Fast CN350B Nail Gun. It is new to me, and I dont have a operating manual for it. I have heard they accept multipule guage nails, is this true? Also can the nail driving depth...
They use 20 degree, full round head, plastic coalated nails. You can shoot nails ranging in guage from .099 to .131 and I believe from 2 3/8" to 3 1/4" length. It is a heavy but well built and powerful tool. It's not made anymore because Duo-Fast has long been sold to ITW which also owns Paslode. The owner of Duo-Fast (third generation, family owned) got very ill with cancer and ended up passing away quite a few years back. I worked as a sales rep for Duo-Fast in the early 1990s. I can not find an owners manual link for you. They don't have an adjustable depth but they do have a flush adapter. Here is a link to a parts diagram. The flush adapter is part number CN-133 and is held on with a screw.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/duofast/CN-350B
Jul 17, 2011 | Tools & Hardware - Others
I have a duo fast CN 350 nailer and it works ok but it don't seem to let the driver blade to come up high enough to get on nail head
You will need to pull the top off to get to it to check it out, If the drive pin is bolted on, make sure the bolt didn't loosen up, most are one piece, welded on, If you don't find anything in there preventing it from coming up, I would grind off the tip, nice and square and flat, then put it back together. I have a feeling you will find a piece of white plastic holding the piston down, part of the head there, It will need to be replaced. Check it out, hope this helps.
Dec 29, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I need drivers for my tst corp cd\dvd rw ts-h552u
Hello jrock123,
Please check this out,
http://drivers.softpedia.com/get/FIRMWARE/Samsung/Samsung-TSH552U-firmware-101.shtml
Hope this helps.
Art Pena
Nov 20, 2009 | AOpen Computers & Internet
Air Tools & Compressors Logo
70 people viewed this question
Top Duo Fast Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
yoopertech
Are you a Duo Fast Air Tool and Compressor Expert? Answer questions, earn points and help others
