Batch simulator ladder diagram in logic pro
How to get bacth simulator to run continuos
Number 2 is chosen to begin a ladder diagram to find the prime factorization of 66. What other numbers could have been used to start the ladder diagram of 66?
By changing the number for your prime factorization, you also have a different diagram.
Prime factorization for 66
66
2*33
3*11
Even if we change the prime factorization order, we still have the same numbers.
66 = 2 * 3 * 11
Feb 23, 2017 | Cars & Trucks
What cables do i need to connect to a t.v. to get surround sound please
It depends what the source of the sound is. If you are using a dvd player or hifi/dvd combo that has surround, dobly pro logic, surround simulation or cinema sound...it will have HDMI, Optical, Digital outputs. The newer items use the HDMI to send Audio and Visual signals to the Hifi. If not...you will either have to do the simulation on your hifi if it has that feature. You can also use the SPDiF or Optical cable from your source to the hifi. If all that is missing...the standard 3-way RCA cable (Yellow,Red and Black) will do where yellow is video and the red and black is the stereo source of sound.
Apr 24, 2014 | Technics SC-DV290 System
Whent I connet my android to my samsung HTC55 using the aux 2, just one speaker work, that is correct? is there a way to connect my android and all my speakers work
Your Android phone can only output in mono or stereo, but it does not have a surround sound decoder, so it cannot output natively to a 5.1 surround sound system. However, your HTC550 has a Surround Sound Mode called Dolby Pro Logic II, which will simulate 5.1 sound from any stereo input. Try activating Dolby Pro Logic II mode on your receiver to get surround sound on your Android phone.
Apr 28, 2011 | Samsung HTC550 Theater System
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
I am having trouble getting my surround sound to output my foxtel dvd using standard av cords is there anywhere i can get a diagram
Hi, I'm not too sure what you're asking - do you mean that sound is only coming out of 2 of the speakers? A lot of foxtel shows aren't meant for surround sound - usually only box office movies.
For best results, use a digital optical cable (not the one with a round end, one that's fibre optic, say that to a store and they will give you the right one) - connect to the optical/toslink input of your surround sound system.
You may have to turn on "dolby pro logic 2" to get all speakers working on some shows. Or you can try just plugging in the 2 red/white stereo cables into the amp, and using pro logic that way. Pro logic creates surround sound, even when your show is only stereo.
I guess that will do it .
Have a nice day.
Mar 02, 2011 | Yamaha Audio Players & Recorders
I'm going to surround sound mode, and my rear speakers are not working. I do a tone test, and they def work, but I can't get them working right?
Since you seem to be having problems with 'simulated' surround, how does ACTUAL surround material behave?
Have you tried AFD with certifiable multichannel source material to verify the surround speakers receive programmed sound??
Do the Dolby Digital or Pro Logic indicators light?
What about the other modes?
Mar 20, 2010 | Sony STR-DE475 Receiver
Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
Mar 24, 2009 | Audio Players & Recorders
RB INV DATA 0001 Error PC Charge Pro Version 5.1.0
The best solution is to have tech support remove the offending transaction from the batch, and then settle the batch. Since it is just a pre-auth, you'll need to run a post-auth to complete the transaction anyway, so it's not a big deal in this case. In the case of it being an actual sale transaction, you would have to remove the transaction from the batch, and then re-run it through PCCharge as a post-auth.
If you don't want to deal with VFI's tech support (I wouldn't either), then depending on your version, you may have more options. If it's a later version 5.7.x and up, there is a batch utility that will allow you to remove the transaction by yourself. If you are using an older version that does not include the batch manager utility, you could rename the batch file (in case you need it later) and in the case of 2 transactions, re-run them in directly in PCCharge as post-auths. Verify that the correct transactions are in in the batch, and then settle as normal. (just as an FYI, pcc tech support will not rebuild any batches with less than 50 transactions. So it might not be a bad idea to learn the batch manager and/or renaming files if you are sticking with PCC).
Jan 15, 2009 | Go Software Inc. PCCharge Pro...
S7 226 Siemen's Plc programming
Hi there, you can check out this link Learn PLC programming.
This web site runplc.com is great resource for anything you like about PLC programming, free programs for programmable logic controllers, and much much more about PLC programming basic
Feb 04, 2008 | Computers & Internet
Getting sound when in telly mode
You have to use the switch on the pro - logic simulation. Your remote button might say sound or PII(with an icon). Usually if you continue to press the buttion you will cycle this different presets, ie. Music, Movie, Cinema, etc. These are optimized for the type of media your using, but try them all and see what works.
Jan 04, 2008 | Sony DAVHDX265 System
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
