Question about Intel DP55KG Motherboard
Don't start but the led of stand by it's on, the energy it's ok on the motherboard
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Check ram
Posted on Mar 30, 2014
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
How can I be certainty that my motherboard is bad
GREEN = POWER IN MOTHERBOARD.
BLUE = STAND BY.
YELLOW = POWER TO MEMORY
OR ARE YOU MEANING FRONTPANEL-CONNECTIONS.?
WHEN THE COMPUTER STARTS YOU GET GREEN.NOT ON STAND BY.
Jun 27, 2013 | Computers & Internet
How to access sleep mode in ga-h61ma-d3v
YOU ACCESS TROUGH START.
THE LED ARE NOT FLASHING THEN HDD ARE IN SLEEPMODE.THE PC SAVING ENERGY.
Apr 28, 2013 | Gigabyte GA-H61MA-D3V Motherboard Core...
Show all solution to d945plrn motherboard problem not powering up
PSU IS OK? You're sure? You tested the 3 main voltages coming out?
DON'T rely on; "The LED lights are on, and the fans spin, so therefore the PSU must be good.
1) If ALL the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor uses 51 to 125 Watts of power.
With a Power Supply that has a weak voltage power rail, you will see LED's light, and fans spin; BUT not enough power to turn the Processor on.
Power Supply also needs to be plugged into motherboard to test, because you need a Load on the Power Supply.
PSU is KNOWN to be good? I mean KNOWN.
Not, "It's brand new so I know it has to be good"
Okay, moving on.
CPU OK?
How did you test it? Install on another working motherboard?
Are the Electrolytic Capacitors on the motherboard good?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Capacitors on the motherboard are used as Filters, and Voltage Regulators.
The ones used as Voltage Regulators are in the Motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Part of what the Motherboard Voltage Regulator Circuit does, is to regulate voltage for the Processor. (CPU)
The CPU MUST have a steady, 'clean', supply of voltage, and it MUST be kept within the Processor's voltage tolerance range.
Too much, or too little, and the CPU shuts off. BIOS turns it off.
(CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
I know you are aware, just posting for all those who read the solution in the future)
http://downloadmirror.intel.com/15140/eng/D945PLRN_ProductGuide02_English.pdf
[Better motherboard due to the Intel Q965 motherboard chipset,
http://www.ebay.com/itm/INTEL-DQ965GF-CORE-2-DUO-LGA775-SOCKET-P-4-MOTHERBOARD-I-O-FACEPLATE-INCLUDED-/290863623024?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D5685984037376928917%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D330632928551%26
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to Q965 in left column ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 18, 2013 | Intel D945PLRN Motherboard
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
About MSI K8N Neo4
http://www.fixya.com/support/p298028-msi_k8n_neo4_f_motherboard/manual-15408
Sep 14, 2009 | MSI K8N Neo4-F Motherboard
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Post
hi i also have a crosshair mobo and it will not post or start up if the internal blue led's are on switch them off on the back and i'm sure it will start
Aug 24, 2008 | ASUS CROSSHAIR Motherboard
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Intel DP55KG Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
