Question about Ranch Hand FBF921BLR Legend Front Bumper Ford F150/F250/F350 1992-199
How to charge after installing new ac lines
How much ac oil to add to compressor?
    Sergeant:
    Champion:
  • 253 Answers
First you have to have a vacuum pump to purge the system, if you don't then you should probably go to a repair garage that works on a/c systems
Posted on Aug 14, 2014
Ac compressor oil
Yes you should add oil before installing. Simple add 3oz for every pound of freon your vehicle requires for a full charge. Pour the oil directly into he compressor through the openings that the hoses attach to.
Jul 30, 2013 | 2003 Chrysler 300M
How to take out air condition compreser out of a2001 mercury sable
have dealership discharge airconditioning system.you need to disconnect refrigerant lines going to the AC compressor you probably need refrigerant lines disconnect tools to remove disconnect refrigerant lines.you need to remove drive belt.and safely raise support vechicle remove tire or wheel work from under vechicle you have to loosen AC COMPRESSOR bolts then remove AC COMPRESSOR.be sure pour old refrigerant in a measuring cup so you can pour same amount new oil in the new compressor.add couple ounces if old AC COMPRESSOR dry.
Feb 11, 2013 | 2001 Ford Taurus
NEW AC COMPRESSOR MAKING NOISE
Did you add the correct amount of oil to the compressor? Is it overcharged? Did you evacuate all the air with a vacuum pump before charging? Was the fixed orifice replaced? If you are sure you did the install right and the oil and charge are correct you have another defective compressor
Jan 25, 2012 | 2005 Chrysler Town & Country
How to replace ac compressor to a 2003 f 250 5.4
An Air-Conditioner loses its fizz with passage of time due to constant usage or wear and tear.Just dial to Dailfix they will help you with all things.
AC Repairs Services in Hyderabad Dialfix
Jul 15, 2011 | Ford F-250 Cars & Trucks
How much oil do i put in my 2000 dodge stratus air conditioner compressor?
Most the time its 8 oz,, need to check with the seller and see the specs on compressor,it should say on ac compressor
Aug 22, 2010 | 2000 Dodge Stratus
Hi..i had to change a/c condencer, and the a/c compresser, both at the same time.how will i go about charging the system? do i need to add coolent too both ports? or just the low side.?
YOU TAKE TO A GARAGE LET THEM PUMP IT DOWN FIRST MAKE SURE YOU PUT THE RIGHT AMOUNT REFRIGERANT OIL IN COMPRESSOR.IT COME WITH SHIPPING OIL IN IT BUT YOU HAVE TO POUR IT OUT.PUT IN THE RIGHT AMOUNT OF REFRIGERANT OIL IN COMPRESSOR LOOK IN OWNERS MANUAL TO PUT IN THE RIGHT AMOUNT.NOW IF YOUR OLD COMPRESSOR SEIZED OR LOCKED UP THEN LET GARAGE FLUSH OUT METAL SHAVINGS OUT .IF YOU DONT FLUSH OUT SHAVINGS THE NEW COMPRESSOR WILL BE DESTROYED.ALSO YOU HAVE TO REPLACED THE ACCUMULATOR OR ORIFICE TUBE IF EQUIPPED.IF OLD COMPRESSOR DIDNT LOCK UP.PUT NEW REFRIGERANT OIL IN COMPRESSOR IT TAKE AT LEAST 1 OUNCE OF OIL BUT CHECK OWNERS MANUAL ALL VECHICLE HAS DIFFERENT SPECS.AFTER COMPRESSOR OIL BEEN PUT IN EVERYTHING ALL REFRIGERANT LINES TIGHT.TAKE VECHICLE TO A GARAGE THAT DO AIR CONDITIONER WORK.THEY HAVE TO USE A VACUUM PUMP TO PUMP DOWN THE AC SYSTEM TO REMOVE MOISTURE AND LEAK TEST THE SYSTEM WHILE IT PUMP DOWN.IF YOU DONT LET THE GARAGE PUMP DOWN SYSTEM. THE MOISTURE WILL FREEZE UP IN AC SYSTEM CAUSING POOR OR NO COOLING.THE GARAGE GOING TO CHARGE YOU TO PUMP DOWN AND CHARGE UP SYSTEM.IT WOULD BE CHEAPER TO DO THIS THAN TO BUY A VACUUM PUMP AND MANIFOLD GAUGE SET.WHEN DOING AC WORK YOU NEED SPECIAL EQUIPMENT AND TOOLS TO DO THE JOB OR THE AC SYSTEM WILL NOT WORK RIGHT.
Jun 12, 2010 | 2004 Nissan XTerra
How do i charge the air conditioner on a 2000 ford focus. Where are the connectors
Look for the ac compressor,and locate the large ac line coming off the ac compressor.Follow it until you come to the ac charge port.this is where you charge it up with a charge hose that you have.Put the can on the can tap,and the quick connect to the ac port on the ac.Turn the t handle on the can tap clockwise until all the way down.hold the can upside down.start engine and turn the ac on high blower.and recirculate.shake can lightly,until the can empties.Turn the t handle counter clock wise,almost all the way out,and remove the can .Repeat to add another can,Don`t put too much freon in,and add ac oil also.If it lost freon,it lost oil,failing to do this could cause the ac compressor to lock up.One 4 oz can will be fine.look for the large ac line to get cold,and the accumulator to get real cold,then stop with the freon.
Aug 29, 2009 | 2000 Ford Focus
How to replace ac compressor for 2001 chrvy tahoe?
take the serp belt off, remove the 4 bolts on top. remove the bolt holding the lines. unplug the plug on the back of compressor. remove compressor. drain oil out into a measuring cup. use a snap ring pliers and remove the senor. with new compressor install the old sensor. drain the oil out of new comp. there should be a total of 7 oz pag 150 a/c oil. add to new oil until there is 7 ozs. put back into comp. install back into car in the same order. when done go to a shop and have them charge the system. tell them what you did so they don't add any more oil into it. change the dryer at the same time. don't oil it. no warranty if you don't change it. best of luck
Aug 07, 2009 | 2001 Chevrolet Tahoe
How do I fill air conditioner coolant.compressor is new, but I need to add coolant.
You need to evacuate mositure with a vacuum pump and then add a can of r134a with oil in the can. Then add more cans without oil. Up to the amount on the decal under the hood.
The low side charge port is behind the passenger fender well. Remove tire and the 7 fasteners holding the plastic fender liner in.
Jun 30, 2009 | 2000 Ford Focus
Ranch Hand FBF921BLR Legend Front Bumper Ford F150/F250/F350 1992-199 Logo
50 people viewed this question
Top Ranchhand Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ranchhand Vehicle Part and Accessory Expert? Answer questions, earn points and help others
