Question about Sun Mountain Speed Cart V1
My bracket that holds golf bag in is snapped off where can i get a spare
Where can i get a spare
Where are the clips at to take body off a golf cart. Yamaha gas, trying to put seats.back on
Lots of stuff here. Remove the drain tubes then remove the bag rack, seatback, and bottom of top supports. Remove the two 10 mm bolts in the bagwell.
Remove the seat bottom brackets from the body and the two pushpins.
Now you have to remove two pushpins on each side, one is under the side panel and the other is in engine compartment. These pushpins are at the rear of the side panels. Should lift up off the cart.
Apr 11, 2017 | Golf
How do I fix the stand on this golf bag?
I would definitely take the bag to a pro shop or specialty shop if I wanted to do a repair. A pro will know whether the bag would be worth repairing or not
Jan 11, 2015 | Golf
How many golf clubs to the Iron Horse Caddy Bag hold?
It is meant to hold a total of 14 golf clubs.
Jan 14, 2013 | Golf
How do I remove the bag
unzip cloth bag look at paper bag it may have a spring loaded mech. holding it or it just snaps in place look at your replacement bag to see if its slotted it probably snaps into place watch how you remove the old bag and repeat the process
Jul 04, 2012 | Oreck XL2200 Bagged Upright Vacuum
How to remove two pins holding ignition clyinder lock tumbler from 1994 mercury tracer
Removal & Installation
Before continuing with this procedure, make sure to have available a new steering wheel retaining bolt and two lock cylinder retaining bolts. Once removed, these parts lose their torque holding ability (or retention capability) and must not be reused.
  1. If equipped, disarm the air bag system and disconnect the negative battery cable.
  2. Remove the steering wheel.
  3. Remove the combination switch.
  4. Unplug the wiring connector to the ignition switch.
  5. Remove the ignition and shifter interlock cable mounting bracket bolt and position the assembly to one side.
  6. Remove the four steering column bracket bolts and lower the steering column.
  7. Cut a groove in the ignition cylinder bracket bolts with a chisel and hammer or use a similar method.
  8. Using a screwdriver, remove and discard the bracket bolts.
  9. Remove the ignition switch lock cylinder and bracket.
Unfasten the ignition and shifter interlock cable mounting bracket bolt, and position the assembly to one side
Use a chisel and hammer to cut a groove in the ignition cylinder bracket bolts-1991-96 models shown; 1997-99 models similar
To install:
  1. Install the new ignition switch and the bracket into position on the steering column tube.
  2. Install the new lock cylinder bolts and tighten the bolts enough to hold the switch in position.
  3. Check for proper switch operation by rotating the key to each position. If necessary, reposition the lock cylinder until it operates properly.
  4. If positioned properly, tighten the retaining bolts until the bolt head shears off.
  5. Raise and position the steering column. Tighten the bracket bolts to 80-124 inch lbs. (9-14 Nm).
  6. If equipped with tilt column, remove the upper mounting bracket retaining pin.
  7. Position the interlock cable bracket. Install and tighten the retaining bolt to 35-53 inch lbs. (4-6 Nm).
  8. Attach the wiring connector to the ignition switch.
  9. Install the combination switch.
  10. Connect the negative battery cable.
  11. Confirm operational status of the air bag system by turning the ignition key to the RUN position and visually monitoring the air bag indicator lamp in the instrument cluster. The indicator lamp should illuminate for approximately 6 seconds and then turn OFF. If the indicator lamp does not illuminate, stays ON, or flashes at any time, a fault has been detected by the air bag diagnostic monitor.
  12. Check the steering wheel, horn and combination switch functions for proper operation.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 30; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Nov 20, 2010 | Mercury Tracer Cars & Trucks
Ogio Stand Bag - Broken "H" Clip
Mine slide up and down the legs. Not a good design since the weight broke 1 of them. I have not found a replacement part for this yet.
Dec 08, 2009 | Ogio Golf Stand Bag
Speedometer quit working
it's in a heat protective insulating bag with a snap button on top of the differential housing.
Apr 30, 2009 | 2000 Volkswagen Golf
Looking for sportster hard saddle bag installation instructions
nstructions Difficulty: Moderate Things You’ll Need: Step1 Determine what type of saddlebags you will be installing on your motorcycle. Saddlebags come in hard and soft styles, with each installed in basically the same manner. Hard bags tend to offer more security for your items but are a bit on the bulky side, while soft bags offering a little more flexibility. Step2 Check to make sure that your fender bolt area is clean and prepped for installation of your saddlebags. Both hard and soft saddlebags on Harley Davidsons are installed over the fender bolt area on the rear of the motorcycle, so clearing this area of debris and grime will keep it free of scratches and blemishes. Step3 Install any spacers or lifting brackets before you try and place your bags on your Harley Davidson. These spacers will keep you bags from resting against your exhaust pipes and will avoid damage to your motorcycle and to the bags themselves. Make sure they are installed tightly and spaced properly before mounting your bags. Step4 Open the saddle bag packaging and lay out the included hardware. The hardware will be necessary to properly mount your saddlebags to your fenders, so be sure that you do not misplace it. If your saddle bag comes with a fender mounting bracket, install it along the fender before proceeding. This bracket will be used to hold and stabilize your saddlebags, so it is essential that it is properly tightened and installed. Step5 Hold your saddle bag up to the fender and align the bolt holes in the saddle bag with the bolt area on the fender. Your saddle bag will have mounting holes in the side of the bag that will align with the mounting bracket. Place one of the bolts in the hole and tighten to hold it on. Put the remaining bolt in place and tighten them both securely once they are aligned correctly. Step6 Repeat this process with the remaining saddle bag. The bags should align evenly and be attached straight to avoid any imbalances or shifting while the motorcycle is in motion. Try and wiggle or move the bags to be sure your bolts are tight enough to prevent movement. Step7 Take your Harley Davidson for a short ride. Stop and check the fitting on your saddlebags and look at your bolts. Make sure nothing has moved during your ride and that all of your fittings remain tight. With just a bit of effort, your new saddlebags will make your Harley Davidson the envy of the neighborhood.
Nov 11, 2008 | 2006 Harley Davidson XL 1200 C Sportster...
Water cooling
u have to be more spesific, but it may slide in to a fixed bracet and just poped out
Aug 01, 2008 | 1989 Volkswagen Golf
Sun Mountain Speed Cart V1  Logo
32 people viewed this question
Top Sun Cycling Experts
Tom Chichester
Bill Boyd
Donald Ayers-Marsh
Are you a Sun Cycling Expert? Answer questions, earn points and help others
