Question about Philips 55pfl4706/f7 TV
Won't power on
Won't power n by back button or remote
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Power door lock switch?
Sounds like the drivers door lock switch is bad an as far as the auto start remote the contacts under the button get dirty and won't make contact, open the remote like changing the battery and you can probably get at the contact button, if it's a little carbon button they can be cleaned with a pencil eraser and then paper tower with a bit of rubbing alcohol, if it's an actual switch you can try spraying some contact cleaner into the switch. let it dry before you put the battery back in.
Nov 11, 2012 | Ford F-150 Cars & Trucks
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
Dvd won't power on
For Volvo Xc-90 2005, same problem with only one headrest dvd working. Start playing a dvd in the working headrest, point the remote at the non working headrest, press media button. This should switch the input back from auxillary to dvd. Tell your kids to never press the media button:)
May 16, 2012 | 2008 Volvo XC90
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Apr 02, 2012 | 1991 Ford F250
Tv won't come on
unplug, remove back and check to see if any bulging capacitor caps, if so, replace them....worked for me on Vizio
Feb 09, 2012 | Televison & Video
Remote control won,t work
This is how to complete a remote reset for a Sharp television:
Turn off the television if it is on. Unplug the television. Please leave it unplugged. Take the batteries out of the remote control. Leave the batteries out of the remote control. Is the television still unplugged? Yes? Good leave it that way. Are the batteries still out of the remote? Yes? Good leave them that way. Point the remote at the television's remote sensor. Hold the power button down for 30 seconds. Release it. Press and release each button on the remote control. Plug the television back in. Turn it on with the power button on the television itself. Replace the batteries. Try adjusting the volume. Hopefully the remote works. If it still doesn't work the remote sensor on the television could have gone out or you may need a new remote. http://www.sharpusa.com may have a remote you can order or http://www.replacementremotes.com but if that isn't the problem you may or may not be able to return the remote.
Sep 23, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
Philips 55pfl4706/f7 TV Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
