WAE24167UK MANUAL WHICH IS A QUICK WASH
Why does it take 3 hours for a wash
Most machines have different wash cycles for different materials. A cotton wash usually takes longest. Most machines also have a quick wash program that takes around 35 minutes. It usually tells you on the dials which programs are available. Read your manual for instructions. If you don't have one you should be able to access one on line.
Jan 13, 2016 | Washing Machines
The quick wash takes over an hour any suggestions how to make it quicker?
The manual says wash number 5 takes 60 minutes the only shorter cycles are numbers 9 & 10 which take 55 minutes but they are cooler washes for wool and silk with a spin speed of 800rpm the number 5 has a spin speed of 1400rpm.
Apr 26, 2015 | Hotpoint Aquarius WDL540P White 60 cm...
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
Does zanussi aquacycle zwf1632w have a quick wash cycle
yes your that model has a quick wash its about a 45 min wash have you looked in your manual it will tell you how
Nov 17, 2011 | Washing Machines
Does it have a quick wash cycle?
I'm sorry but does what have a quick wash cycle? You have forgotten to tell us the make and model;-0(
Methinks you could do with a manual for your washer- for now and probably later!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 31, 2011 | Washing Machines
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
Can you please tell me how to do a quick wash on the beko wm5120w washing machine,.
The only washing machine they have a manual listed for on their site is the WM5140.
CLICK HERE
Should be similar to yours.
You can only select QUICK WASH in 6 programs - listed on page 18 of the manual.
Simply select the program desired, and click the Quick Wash Button.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2009 | Washing Machines
I have no manual to my washing machine and do not know what is the quickest wash on my machine. Its a beko wm5 120
Try locating the manual on Beko download page, click the link below to open the download page:
Manual Download Beko
Apr 17, 2009 | Washing Machines
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
