Question about Garland Kitchen Ranges
Rcs48-6g Schematic for oven no power to igniter
Oven won't turn on after grill repair by service tech
may have accidentally turned the oven safety gas valve off by mistake
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 26, 2015 | Ovens
FGB24L2AB wont ignite
I found the electrical schematic. You will have to create an account to view it.
You have an oven control box which receives power, has a thermostat attached and provides power to the ignitor which must flow through the bake valve.
Can you smell gas? Is the ignitor getting power? (must use a multimeter).
It may be possible that the ignitor can be visibly checked. If it is cracked, replace it. The ignitor itself should read no (or extremely low) resistance.
:o).
Jun 04, 2011 | Ovens
I have a Whirlpool Super Capacity 465 Gas Range. However all the burners on top will not click to ignite. I turned the breaker off and that back on again and it worked for a day or two. Now nothing will...
Power for the ignitors goes straight from the input power to the burner switches then on to the ignition module. The burner switches are in series parallel. Any one of them actuated will provide power to the ignition module.
See the schematic in this pdf file page 22 but page labeled pg 20: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf
When the ANY burner control is turned on all 4 ignitors do cycle.
Does the oven burner light? If not you most likely have a bad ignition control unit. Item 35 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=242126&diagram_id=32025#d32025
If the oven burner lights then you most likely have a wiring problem to the burner controls. There is ONE power lead that if it comes loose will cause all of the ignitors not to work.
You can use the https:// manual link above to gain access to the top of your oven. See page 15 of the .pdf file.
The igniton system is explained starting on page 19 of the pdf file.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Whirlpool Kitchen Ranges
Oven won't ignite,burners work broiler works. Is a wiring diagram and schematic available ? Amana Model ARG7300LL ;Mfg.P114332ONLL
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 18, 2010 | Kitchen Ranges
I would like to find an electrical schematic for a model JES1036PWH03 GE microwave oven. Oven is dead, no power to control panel or light. Power thru fuse is good.
Couldn't get a schematic from GE. CSR told me they consider the unit a throwaway if it fails. Only parts they stock are the glass turntable and the roller ring. I ended up probing and metering the 110v power circuit. I found an open thermal cutout that was preventing power to the control panel. I removed it and took it to a local parts store and matched it up with a generic cutout with the same specs. Installed new unit and the oven is working like new. Cost: $15.00.
Oct 05, 2009 | Microwave Ovens
Gas oven igniter glows, but oven does not turn on.
That is correct. You will have to check if the valve needs replacement or if there is power being sent to the solenoid for the valve. There must be just a connection problem.
Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Vulcan convection oven has pilot lit and fan blows but no ignition. The schematic is too small, grease smeared and partly ripped to be of use. Is a schematic available or is the cause obvious to an...
The list of problems is as long as the one Obama inherited when he took over. Good news though, the most expensive part works, the blower motor! The pilot is established which rules out a gas issue. The two most common problems are, either the temp controller or the infinate switch is bad. Your unit has one or the other but, not both. Controller has several wires leading to it & has a green or tan circuit board on it, infinate switch is a small black or white 2 inch square box with 4 or 5 wires leading to it. Each one of these are mounted thru the front control panel & both have knobs. Temp board around $180, infinate switch around $45. As far as the schematic is concerned, Vulcan was bought by Hobart & they DO NOT give out schematics or service manuals.
Jul 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
HI thanks for your question. the part that is faulty is the igniter, it does not get hot enough to ignite the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Jul 09, 2008 | KitchenAid KESC307 Electric Kitchen Range
Schematic for GE JGRP18GEL
We went to General Electric and requested the schematic for our
oven, they immediately faxed it to us, and also are sending a copy
in the mail.
All we needed was the schematic for the timer/control.
So, in the future, you can remember this....
Mar 10, 2008 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
24 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
