Question about Yamaha HTR-5140 Receiver
Won't work right
Show a code in front ext. decdr
What to do when drum heater does not work
you need to replace the drum and power suply as well
Feb 11, 2014 | Canon PTCH DECDR 6050/7550/9550-INST REQ...
Ext in problem
if you are using the ext in then it has to be something wrong with the setup from the pc. The receiver does nothing to the ext in input except amplify it and put it out to the speakers.
Jan 14, 2014 | Denon AVR-1907 Receiver
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
I just bought the usb connector for the sansa sandisk c150 mp3 player and my computer will not recognize it when I plug it in.
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
PLEASE RATE YOUR ANSWER
Aug 13, 2011 | SanDisk Sansa c150 MP3 Player
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
SX-50 Mitel wake up calls won't go through to rooms. Is there a way to reset or fix this?
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
May 18, 2011 | Mitel 9104-001-000 Power Supply SX-50...
Starter on 2004 chevy trailblazer
If you can't get the key out of the ignition, it's probably the ignition switch (where the key goes in) that is bad, not the starter. The starter is on the right side under the exhaust manifold behind the right front wheel. It's not easy to change on those unless you know what you're doing.
May 30, 2010 | 2004 Chevrolet TrailBlazer
I have EnGenius EUB-362 (EUB362 EXT) not working
Open your device manager again and go down to the bottom where the USB controllers are. Click on the plus sign and right click on the "standard enhanced pci to usb host contoller" Click on disable. Reboot and when you do you may have to unplug the EUB 362 EXt and plug it back in. You should then see the grey bars in the lower right of your screen where the two monitors are. Then click "Start" and then "Connect To" and your available networks screen should pop up. Double click on the network you want to connect to and away you go.
Jan 31, 2009 | EnGenius EUB-362 (EUB362 EXT) Wireless...
7453 Display
Without looking up details on versions, I think you may have an early D1232. Look at the plate on lower edge/front and see if there is a number in a circle. If there is no version number, the serial number will tell when the system was made.
Jul 07, 2008 | Panasonic KX-T7453 Corded Phone
Yamaha HTR-5140 Receiver Logo
15 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
