Question about Canon ZR60 Mini DV Digital Camcorder
Lcd screen black when recording. vcr playback only sound
When i try to record the lcd screen is black but shows rec.  then when i do vcr playback all i have is sound.  I have only used the camra maybe four times in the past year and a half.  still trying to learn how to use it.  is there anything I can do to fix this?
  • 6 more comments
  • goldberry Nov 04, 2007
    I have the same problem and Canon was no help. I think it is a manufacturer defect and it should have been part of the recalled camcorders.
  • mikemitch435 Dec 14, 2007
    I have a Canon ZR60 DV Digital Camcorder and I have the same problem. The LCD screen goes black while recording, but the record light stays on. In VCR mode, there is sound but no video.
  • rabidzebu Dec 21, 2007
    I have that same problem and it pisses me off. Sometimes after fiddling with stuff I can get it to work for an hour or two, but then it just goes back to the way it was and if I do the same thing to try and fix it as I did the first time, nothing happens. >:(
  • Goce Apr 06, 2008
  • Anonymous Apr 09, 2008
    Same problem, though we seem to be able to view video with sound in the playback mode.
  • Anonymous Apr 10, 2008
    i have the exact same problem only i had the darn thing for one year and hardly used it . i can see video in playback. my waranty is up is there any recourse?
  • sparky1562 Apr 12, 2008
    Same problem, no video but sound.
  • tiffvanv May 02, 2008
    I have the same problem and I looked online and there is a notice of this product having the ccd censor damaged from heat or humidity there is a customer service number 1800-828-4040 they will send you paid shipping lables and repair for free.
It seems a CCD sensor's problem. check the link out, it should be repaired for free
Posted on Apr 20, 2008
Smash your camera with a baseball bat and buy a new one because the company is designed by a jerkface who likes to rip people off.
Posted on Jan 04, 2008
I contacted Canon via e-mail and they are going to fix the problem for free and pay the shipping. You should go to and send them an e-mail or call them.
Posted on Nov 05, 2007
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
Option window will appear.
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
Timer Programming
Auto Finalize
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
Using [
K / L], select “VCR DVD”. Hit [ENTER].
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
VCR to DVD duplication will start.
C] to stop the
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Jul 20, 2009 | Canon ZR80 Mini DV Digital Camcorder
Need manual for Funai SV2000 Model#WV20V6
Visit and under manual type your model to download pdf.
Jan 06, 2009 | Funai TruTech DVDVCR Dual Recorder
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
VCR Play Back is OK, but Recording produces Blue Screen on playback
If the heads are TOO dirty, a head cleaner will not help. If you are cinfident enough to open up the recorder, then they can be cleaned manually.
Disconnect the VCR from the mains.
Remove the screews from the side and back (if applicable) of the lid.
Remove the lid.
Look at the large drum (set at a slight angle) If you gently rotate the drum you will see 2 or 4 small sensors set into the drum.
Tear of a clean piece of A4 paper about 1inch square.
Hold between thumb and first finger and rub the centre of the paper against each sensor in turn. Make sure the edge of the paper does not catch the sensor.
After each sensor check the paper for dirt (black marks) and change paper if need be.
Try a recording / playback.
Repeat if necessary.
Nov 08, 2007 | Philips VR330 VHS VCR
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Canon ZR60 Mini DV Digital Camcorder Logo
185 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
