Question about Xplore Technologies Xplore iX104C2 Tablet PC
XP8801B white screen
My tablet has white screen. how to fix it? Can I do reset? How?
Why did screen turn white?
probably a connection problem with the board inside,below is a link of how it could possibly be fixed
Android Tablet White Screen fix
White screen and lines on tablet repair no video Fix it Fik
Jan 30, 2016 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
Wont let me go two seconds past the first screan
These are one of the worst tablet ever build.
The problem with the Irulu's tablets is that the hardware is way too low. I fix one for. A friend of mine and every time I had to switch screen it would just go back to a white screen. I had to tur" it off and on again to fix it. My suggestion is to search him for "How to hard reset Irulu's tablet", and if there is any key combination to reset your tablet to the frailty value, it will be at in the search or google. Best of luck.
May 07, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Have 2 tablets only 2 months old 1 won't charge; 1 has plain white screen can't do anything
For the one that is not charging. Is it where it cannot hold a charge or won't make a connection all? Could be a bad battery, or could be the charge port is bent or disconnected. The white screen sounds like it has crashed and won't boot up with its "Operating System" You could try doing a hard reset on the white screen, if that does not fix it then I say it is gone for good and you would need a new one.
Mar 02, 2015 | Tablets & eReaders
How do you fix a vivitar camelio if its screen is white
hello have you had a look on google how to do a hard reboot or youtube may be, or yr tablet will have a reset hole, very small in the side of yr tablet ,when turned on put a thin pin into the hole and press gently and you should feel it click,if this fails then hard reboot.
hope this works for you
Aug 11, 2014 | Tablets & eReaders
Samsung tablet 8 gigabyte white stuck on black screen saying Samsung. How do I fix this?
press the power button and volume up, volume down at the same time, menu will appear after a few seconds and try resetting the tablet, most likely the OS is corrupted.
Jul 04, 2014 | Tablets & eReaders
White screen
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
May 04, 2012 | Philips SA3CNT16K 16 GB GoGear Connect 3...
Xplore Technologies Xplore iX104C2 Tablet PC Logo
22 people viewed this question
Top Xplore Technologies Tablets & eReaders Experts
Hardeepak Bhambh
Hardeepak Bhambh
john1959ny
john1959ny
Level 1 Expert
Denkichu
Denkichu
Are you a Xplore Technologies Tablet and eReader Expert? Answer questions, earn points and help others
