Question about Lexmark MS00321 - X738de Mfp
Defective disk power up and get 61 defective disk error
How do I fix the error 61 remove detective disk
If you mean defective disc, try running chkdsk/f to clear any theoretical errors. Physical errors and not repairable and a replacement hdd is required.
Oct 03, 2014 | Computers & Internet
Error code 61
Disk full (Error 61) loadTOCNode(2, 'moreinformation'); Possible causes for this error are:
  • There is not enough room on the disk for the completion of a Print #, Write #, or Close operation.
  • There is not enough room on the disk to create required files.
To work around this situation, move some files to another disk, or delete some files.
try uninstalling a few unnecessary programs to regain some disk space
hope this helps
Nov 01, 2011 | Computers & Internet
When booting my acer aspire one, (linux based) it comes up with the error media test failure, pxe e-61 pxe-m0f. I have tried changing boot order and taking it apart, looking for loose connections, this...
The POST (power on self test) error pxe e-61 on a laptop means that either the disk controller is faulty or the hard disk is faulty. Please click on this link and follow my instructions to determine the fault and fix :-
Normal 0 http://www.fixya.com/support/r4377704-pxe_e61_error
Oct 02, 2010 | Acer Aspire One PC Notebook
My vaillant ecoTec plus shows F49 , new vrt 360
F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak i pasted the answer below hope it worked
Aug 02, 2010 | Heating & Cooling
Nsm cd wont play
I can't guarantee to solve this but hopefully I can give you some pointers.
ER 61 can point to 1 of 4 possible errors:
1. CD is not recognised
2. No CD in the player
3. CD defective
4. Player defective
When you loaded the CDs did you record the titles into the title memory? If not it is worth running this function first. For sake of time just run this for one disc first to see it is works.
If it still fails then try a different CD. Load the disc detail into memory again first tho.
If you have success with that then run the function for all discs.
Unfortunately if it still fails I think you will need to get a professional to give the player the once over.
Hope this helps.
Apr 28, 2009 | Wurlitzer Jukebox CD Player
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Non system disk or disk error
This error can be a couple of things. If the "boot block" on the disk has become faulty, the system won't recognize that the disk has an operating system on it and will generate this error message. If the disk is defective completely, the same error will occur. If you have a boot floppy or CD, try re-writing the boot block on the disk. If that fails to resolve the problem, the disk is defective and will need to be replaced.
Dan
Feb 25, 2009 | Compaq Computers & Internet
Error -61
First off, anything LACIE is bottom of the barrel. Don't take it personal, but if i have a nickel for every Lacie D2 drive I've had to recover...oh wait, sometime i got more than what people paid for them to recover what was on them........think about it for a second. Error -61 is a bad master directory block. The drive has a directory, like any book or "volume". It's where the drive stores the information based on the location of content on the drive. Which means your drive will fail soon because it will not be able to retrieve what you are putting on it, because it is internally failing.
Aug 26, 2008 | Apple MacBook Mac Notebook
Jukebox error
error 61 on the nsm is a cd read error nothing to do with the amp, clean laser lens with a cotton bud and spit not spirits etc just saliva, then make a blank selection and see if the laser emits red beam, if not then the laser is faulty, check connections etc, if it picks up the disc but does not spin it its the decoder at fault, places like act marketing london, jukebox showroom, capital coin, herondata sales or anyone operator within the amusement industry will gladly sell you an exchange unit, or just try the coinslot industy magazine online or order via wh smiths
Mar 04, 2008 | Audio Players & Recorders
Problems
defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error (such as E:61:20) and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 07, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Lexmark MS00321 - X738de Mfp Logo
230 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
micky dee
Owen Barnes
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
