Question about Coby TF-DVD7100 Portable DVD Player
Reading wrong disk
Is there some type of reprogaramming that needs to be done because it worked for a while then it stared saying "wrong disc" what should I do?
0 characters
1 Points
Disc inserted but NO DISK message appears
Try other discs to see if its still working properly...most likely the recording on the disc is not burnt properly or there's something wrong with the disc, (ie, scratched or surface dirt etc) or the DVD player just can't read the disc...for example can it read the type of disc(does it read dvd+r or dvd-r, or both?--- if i remember rightly)..... I've had discs that have had bad recordings but can still be read if placed into tray a particular way around... randomly try different positions, also cleaning disc as you go...depending on how desperately you want it to read the disc...could also be bad disc batch... there could be many reasons...
Sep 22, 2012 | DVD & Blu-Ray Players
My dvd player says no disc, with a disc in it , what does that mean?
Means it cant read the disk.
Either disk is faulty or your heads need cleaning or you have inserted a type of disk it cannot read ie a rewritable one.
Feb 07, 2011 | Panasonic DVD-S31S DVD Player
Keeps saying wrong disk
The reason it is showing wrong disc is because the laser/lensisnot reading the disc.
The reason the laser/lens is not reading the disc is because it is either weak or dirty.
To fix it if it is dirty, try to clean it with a lens cleaner.
If it does not work, then it means the lens is weak, and to fix the lens you have to replace it with a new compatible lens.
Get the appropriate screwdriver, open up the cover, unscrew the disc tray and try to locate the lens and replace it with the new one.
test with a DVD disc.
Take care
Jun 13, 2010 | GPX D1816 DVD Player
I have a never-been used PD-800 DVD player, when I put DVD in - it says - "wrong disc". What could be my problem? Thx. Ray
there are mauy different dvd applications did you read what type if disc to use a lot of older units use dvd ram disks and can't use regular also try a dvd - disk and a dvd + disk the speed of the disc also plays a roll in weather it will work or not
4x 8x 16x 20x check the manufacture
Mar 01, 2010 | DVD & Blu-Ray Players
When i put in a disk it says no disk
check and see if the cd isnt stratch up or make sure your dvd is clean in the tray try cleaning the dvd player or the cd
Aug 05, 2009 | DVD & Blu-Ray Players
My daughters GoVideo DVD player always says CHECK DISC!
If no disk is detected it means that the lens are dirty or defective.
If the lens cleaner disk, or using Qtips and alcohol did not work, then the lens pickup or the disk drive must be replaced. this involves precision soldering and must be done by a technician. Regards.
Jul 04, 2009 | GoVideo DVD & Blu-Ray Players
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony DVD & Blu-Ray Players
Hope it was the non-acetone type of polish remover - acetone will melt plastic !!
Invest in a laser eye cleaning disk - the kind with the tiny brushes.
OK what type of file format are the files in on the disk you are tying to play?
IDM-1731 does not like .AVIs.
Check your documentation as to what type of files your player can actually read and play.
Sorry I'm not more help.
Mar 21, 2008 | Initial IDM-1731 Portable DVD Player with...
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
Problem with Coby DVD player
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 01, 2008 | Coby DVD-209
Coby TF-DVD7100 Portable DVD Player Logo
23 people viewed this question
Top Coby DVD & Blu-Ray Players Experts
Are you a Coby DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
