Question about Ultratab JAZZ-C925 Tablet PC - MediaTek Cortex 1.2 GHz Processor - Wi-
It wont turn on
My 7 in Tablet is brand new it powered on for a day and it has never turned on since.
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
Dec 16, 2015 | Tablets & eReaders
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
HOW TO RESET IT
1. Make sure that you tablet is connected to the power adopter to maintain power. Do not forget to plug the power adopter to the power socket to charge.
2. Make sure that your tablet is turned on then poke the small circular hole for 1 minute and wait until the tablet turns off and it will reboot it self.
Once the tablet reboots, all of your data has been deleted already and your tablet will just like a brand new that does not have too many applications that has been installed on.
Jun 18, 2014 | Irulu 7 inch Android Tablet PC, 4.2 Jelly...
Ematic 7'' dual core em63
You will likely have to reset your tablet to it's factory settings using the key sequence.. it'll mean you'll have to re-load your data and programs but you'll have your tablet back. Been there more than once... Oh well.. here's the procedure:
Press both the volume up key and the power button key to turn the tablet off completely. Once it's off, press down the power button and the volume key together. Release the power key and hold the volume up key until the "Factory Reset Menu" appears. It looks kind of like a robot with it's chest hatch open. Use your volume up and down buttons to move the selection to "Factory Reset" and press the power button to select it. The tablet will reset itself and you'll be back to a brand new tablet.
Mar 22, 2014 | Tablets & eReaders
I wa downloading some games, wanted to go back to the main screen and now it is frozen on "Tablet pc screen" it wont turn off or do anything
Press and hold the power button for about 20 seconds. You should see some flashing. Let go of the button and watch. It should reset it's memory and come back on. If this does not work then call your tablet's customer service.
Mar 17, 2014 | Samsung Tablets & eReaders
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
My Freelander PD90 tablet wont turn on
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 17, 2013 | Umi FreeLander PD90 10.1 Inch IPS Screen...
Busbi 7 wont load just stays on android robot screen
Problem solved! The support at Busbi actually turned out to be quite responsive. Reply as follows:
Thank you for contacting support, sorry to hear you are experiencing issues with your tablet.
Can you please try a factory reset on the device, Connect the USB lead to the tablet and your computer please leave for 10 minutes remove the cable power down the unit if the unit powered up, press and hold volume + also power keep held until you see the bees, release both keys.
Use volume - navigate down to wipe data / factory reset
Press power
Use volume - navigate down to yes -- delete all user data
Press power
After formatting system will be back at the menu
Press power to reboot system now.
Jan 25, 2013 | Tablets & eReaders
Wont turn on
you need to press power button for a while so it'll be turned on.
If not, contact the supplier for help.
Android 4.0 Tablet PC
Feb 07, 2012 | Archos 7 Home Tablet Tablet Android 8 GB 7...
Ultratab JAZZ-C925 Tablet PC - MediaTek Cortex 1.2 GHz Processor - Wi- Logo
12 people viewed this question
Top Ultratab Tablets & eReaders Experts
Are you an Ultratab Tablet and eReader Expert? Answer questions, earn points and help others
