Question about 2wire 2700HG-B Router (2700HGB)
Playstation 3 will not connect to my 2Wire BT2700HGV wireless router. gives me an error code to do with mac filtering yet i cannot find anywhere to type in the mac filter on my routers BT homepage (when i type the IP into the address bar) i'm a 19 year old girl with little technological knowledge so any simply-worded instrucutions would be wonderful;)
  • 428 Answers
Dear
If you have a wi-fi router - you can use PS3's wi-fi feature (available in all models except long gone 20GB). If you have a wired router - just get RJ-45 cable (Ethernet) and plug your PS3 into the router.
After that - go to Network Settings in menu and follow the instructions.
Nac address is not the ip address but the network card ID
Go into the network settings, select connection type.
Pick the wireless option, and select 'SCAN', your Sky router will come up.
Go right, select the type of securing setting (check what type this is by logging onto you router).
Enter the password.
U may require a WAP key for the connection.
Or do something like this
1.Go to network settings in settings menu.
2.Then go to internet connection settings.
3.Then select easy.
4.Select wireless.
5.Select scan.
6.Select your router from the list.
7.Make sure the ssid is correct(The same as the one on the bottom of the router)
8.Select WPA-PSK/WPA2-PSK.
9.Type in the network key that is on the bottom of the router(In capitals)
10.Make sure everything is correct.
11.Test connection.
Hope this would help U dear. Please rate the answer if it helps u.
Thanks
Enjoy
Posted on Jun 15, 2009
Error 8001000b wont allow me to connect to the playstation 3 network anymore. everytime i turn the ps3 on it says error 800100b on the screen then i go to the network settings to try and connect and the...
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.158.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Read more: http://www.ps3news.com/forums/ps3-guides-tutorials/how-fix-wireless-internet-error-8001000b-ps3-98772.html#ixzz1FxUHQxte
Hope this helps. Please Rate
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
No wifi
check your 2wire router if the mac address filterins is turned on and if it is your either get your computers mac address and input in the 2wire router settigns or remove the 2wire router mac address filtering option...
^_^
Jun 05, 2010 | 2wire (2701HG-B) Wireless Router
Will not connect to the internet wireless. keeps saying error 8001000b
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1
4. Select MAC filters.
6. Save entry. At this point router will reset itself.
Or find someone or hire someone who could fix that for you..
May 28, 2010 | Sony Playstation 3 (PS3) Console
Getting error code 8001000a
__you can try this:______
I struggled setting up the wireless internet connection on my PS3. It seemed that no matter what I did, I kept getting the error message 8001000B. After reading some help materials on this website, I determined that I needed to add to my router list of allowable MAC addresses the PS3 MAC address. Once I did this, the setup was as easy as shown on the manual.
Steps:
__or this:___
After looking over the internet for answers I found a fix for the 8001000A and when the Playstation 3 (with firmware version 2.76) is hooked to a wireless router (in my case a Netgear WNR834B v2). Below are the steps I took.
  1. Reset your router to factory defaults.
  2. Go to Select Network Settings under Settings in the home menu.
  3. Select Easy then Wireless.
  4. Then select Enter Manually. Then enter in your SSID of your router. Then rest of the setting should be set to Automatic.
  5. However DO NOT TEST CONNECTION. Just save and turn off the playstation3.
  6. Then turn off Playstation 3 from the back of the drive.
  7. Unplug the power cord and wait 30 seconds.
  8. Plug the power cord in and turn on the Playstation 3 switch.
  9. Wait 5 seconds and turn on the Playstation 3 and it will work. You can even test your connection and it will work.
However if you want your security settings on the router then once the router settings are back then repeat steps 2 through 9. Hope this works for all. I do not think replacing the unit is the answer. Any question just let me know.
Apr 10, 2010 | Sony Playstation 3 (PS3) Console
How can i configure WPA security on my 2wire modem
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 22, 2009 | 2wire Computers & Internet
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Jul 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
8001000b error
2. Open the software controlling the router. This is usually done my typing the router's IP address on your browser. ie http://192.168.0.1
It is also important to go through the connection settings to make sure everything is correct:
http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Hope this helps!
Apr 05, 2009 | Sony Playstation 3 (PS3) Console
Error code 8001000B
Looks like a mac address problem, follow these steps if you feel up to it, or hire someone to do it for you.
Steps:
Jan 07, 2008 | Sony Playstation 3 (PS3) Console
PLAYSTATION 3 WIRELESS NETWORK
get a firmware update for ur router
Mar 29, 2007 | Sony Playstation 3 (PS3) Console
2wire 2700HG-B Router (2700HGB) Logo
748 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
