Question about Admiral Washing Machines
Load lnc6760a71 load maximum
What is the proper tire pressure for P235/70R15 on Chevy Blazer
32-35 psi cold or hot air pressure usually has a 2-3 lbs difference...See Owners manuel or tire man. recommendations..
Feb 24, 2015 | 2001 Chevrolet Chevrolet Blazer
Tyre Pressure for Majestic 19.6 ft Caravan
Depends also on the kind of tyre.
For the maximum load of tyre nex kinds need next pressure , wich is called AT-pressure/maxloadpressure/reference-pressure , for up to maximum speed of tyre or if lower 160km/99m/h. This is not the maximum pressure of tyre.
Normal car tyre /standardload AT 2.5bar/36psi ( exeptions as low as 2.2)
XL/Reinforced/Extraload AT 2.9bar/42psi ( exeptions 2.8 and 3.0)
6PR( plyrating) /C-load AT 3.8bar/55psi EUR ( USA 50psi/3.4bar)
8PR/D-load AT 4.5/4.8 bar/ 65/69/70 psi
From E -load is not often used in Europe.
From this AT pressure you can calculate the needed pressure for lower loads . Made spreadsheet for it in wich I first add 10% to the assumed load before calculating.
Will give example picture
Jan 06, 2015 | Cars & Trucks
Proper loads 4 an Olympia .50 cal. Muzzle loading rifle using pellets instead of powder.
MAXIMUM LOAD WARNING 45 and 50 CALIBER RIFLE:
45 Caliber Pellets come in one size: 50 grain
50 Caliber Pellets come in two (2) sizes:
50 grain volume equivalent which equals 50 grains of loose powder by volume.
30 grain volume equivalent which equals 30 grains of loose powder by volume.
The maximum load per shot should never exceed total Pellets containing more than 100 grains volume equivalent. That means, no more than:
45 Caliber 1) Two (2) 50 grain Pellets
2) Three (3) 44/45 caliber 30 grain
50 Caliber 1) Three (3) 30 grain Pellets, or
2) Two (2) 50 grain Pellets, or
3) One (1) 50 grain Pellet and one (1) 30 grain Pellet
54 CALIBER RIFLE:
54 Caliber Pyrodex Pellets come in one size only:
60 grain volume equivalent which equals 60 grains of loose powder by volume.
The maximum load per shot should never exceed 120 grains (2) Pellets.
Oct 12, 2014 | Optics
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    load
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    laundry?
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Sep 14, 2014 | Indesit W 123 Front Load Washer
Mac serial numbers C07M3AV8DWYL
According to the serial number, the late 2012 Mac mini's maximum Resolution: Up to 2560 by 1600 (Thunderbolt) or 1920 by 1200 (HDMI). However, this mini does not have a slot loading DVD drive.
The last mini with a slot loading drive was made in 2010. That model's maximum resolution is Up to 2560 by 1600 (Mini DisplayPort) or 1920 by 1200 (HDMI)
Aug 20, 2014 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
I can not intall my acer 320u scanner in win 7
Scanner seems to be very old - Here are orginal specs - Hope this helps
  • Brand Name: Acer
  • Model: 320U
  • Hardware Platform: PC, Mac
  • Scanner Type: Flatbed scanner
  • Form Factor: Desktop
  • Scanner Interface: USB
  • Media Size Maximum: A4 (8.25 in x 11.7 in)
  • Color Depth: 36-bit color
  • Maximum horizontal resolution: 300
  • Maximum Vertical Resolution: 600
  • Media Type: Plain paper, Bulk objects (such as books)
  • Media Load Type: Manual load
  • Minimum system requirements: Apple MacOS 7.0 or later, Microsoft Windows 95/98
  • Width: 12 inches
  • Depth: 18.1 inches
  • Height: 3.3 inches
  • Sep 13, 2011 | AcerScan 320U Flatbed Scanner
    Could you tell me the load capacity to the hotpoint wma64 please
    Maximum load 5.5Kg
    Wash Load Examples:
    Two examples
    of maximum
    wash loads for
    different types
    of fabric.
    COTTON
    2 Bath Towels
    5 Shirts
    6 Blouses
    1 pair of
    Pyjamas
    4 items of
    Underwear
    = 5.5kg
    SYNTHETIC
    2 Children's
    Dresses
    4 Shirts
    4 Blouses
    1 pair of
    Pyjamas
    4 items of
    Underwear
    = 3kg
    Jul 29, 2011 | Hotpoint WMA64 Front Load Washer
    Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
    140 watts minimum continuous power per channel, 8 ohm
    loads, 2 channels driven from 20 Hz to 20 kHz, with a
    maximum total harmonic distortion of 0.05% (FTC)
    170 watts minimum continuous power per channel, 8 ohm
    loads, 2 channels driven at 1 kHz, with a maximum total
    harmonic distortion of 0.7% (FTC)
    180 watts minimum continuous power per channel, 6 ohm
    harmonic distortion of 0.1% (FTC)
    Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
    Maximum load
    I solved my problem by choosing a different washing machine to buy
    Jun 11, 2008 | Miele W865 Front Load Washer
    Washing Machines Logo
    19 people viewed this question
    Top Admiral Washing Machines Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
