Question about Dyson DC18 Allergy Bagless Upright Vacuum
Internal hose on DC 18
Replace hose
How to replace Dyson DC17 Brush roller motor
http://www.dyson.com/support.aspx is a good place to start.
Mar 01, 2015 | Dyson Dc-18 "slim" Upright Model...
How to replace heap filter?
There are information videos on YouTube . com showing step by step replacment
Aug 07, 2014 | Dyson Dc-18 "slim" Upright Model...
Long and short tubing
Hi Sharon, it's Jack at Dyson.
To replace the internal hose (the short section of flexible hose underneath the cleaner head), please follow the steps shown in the video above. The internal hose has a push-fit connection at both ends - please make sure it's pushed firmly into place.
To replace the main hose at the rear of the machine, please take a look at our Support guide: http://www.dyson.com/support/dc28/dc28-animal/diagnosis-root-menu/dc28filterwashvid/wand-suction-dc28/wand-from-hose-dc28/hose-suction-dc28/redirect-to-check-the-hose-dc28/check-the-hose-dc28
If you remove the clear bin and cyclone pack from the machine as if you were about to empty it, you should see the hose release tab to disengage the hose from the machine.
I hope this helps, but if you need any further guidance please email askdysonUS@dyson.com, and one of our experts will be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 07, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
I need a parts diagram of a dyson dc 18 that I can read. Please help.
Sorry we do not have this diagram. Contact Dyson, whom I suspect is not going to be very helpful based on previous experiences
Oct 11, 2012 | Dyson Dc-18 "slim" Upright Model...
Our Animal DC14 hose unraveled, can we replace it?
Yes you can replace the hose youself. First buy the hose (through Dyson directly or google to see a list of online retailers). All you'd need to do is to unhook the hose from the bottom - you'll remove the canister/dirt bin and push the lower cord hook/cup off the back of the machine from the front and simply click the new hose into place.
Jun 07, 2009 | Dyson DC14 All floors Bagless Upright...
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Dyson DC 18 Model won't stand upright on it's own
If it won't pop back into the cradle that holds it in standing position, take off the entire hose and check for long items such as pens and pencils.
Feb 02, 2009 | Dyson DC18 all floors Bagless Upright...
Dyson DC18 Allergy Bagless Upright Vacuum Logo
27 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
