Question about Dell POWEREDGE 2900 Server
Keyboard doesn't work in bios screen
Keyboard doesn't work in the bios
Does your laptop work when you plug in a USB keyboard? When you startup the machine, do the keys respond (depending on your laptop, push the key to get into the system BIOS). If it allows you to get into the system BIOS, then it maybe a software issue.
Oct 21, 2012 | Sylvania G-Netbook
The "Up" arrow on my keyboard doesn't work. I
Press F2 at system boot up to enter BIOS Settings and look for brightness option and adjust it accordingly under "VIDEO - BRIGHTNESS. Use arrow key to highlight VIDEO then BRIGHTNESS - Press ENTER.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 27, 2011 | Dell Inspiron 1525 Notebook
I used a PS/2 Keyboard and one day it stopped working. And I found out that when it's installed even the mouse doesn't work, so I bought a new USB keyboard though I can't enter the BIOS with it...
Hi, you maybe just need a driver for the mainboard.
You can download here:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
Try the chipset driver first.
Please unzip the file before installation.
You maybe also need the driver for the usb controller.
Try to use a PS/2 mouse until the driver is installed.
Aug 28, 2011 | Biostar G31-M7 TE Motherboard
Keyboard don't work. It happens 2 weeks ago, now
Is the keyboard working in bios mode? if Still not working. Go to the nearest service center. Tnx
Aug 18, 2011 | Computers & Internet
I Have a 945GZM-S2 Motherboard. I want to get into Bios but delete key doesn't work on restart. It would appear that the keyboard is not connected. I have just bought new hard drive and I want to...
The keyboard may be faulty, try a different keyboard, but don't use an USB keyboard because an USB keyboard may not be recognised until Windows is running.
Jun 17, 2011 | Gigabyte GA-945GZM-S2 Motherboard
Some keys didnot work. num and litters
First, try to find out if the issue is related with the hardware or software..
1. go to BIOS
2. press the alphabets which are not working (if you get beep the prob is related with software if not the prob is with hardware)
----------if its hardware related------
1. power drain by removing ac adapter, battery n other accesories connectd
2. go to BIOS n set it to BIOS default
3. check if its working in BIOS page which are not working in the desktop screen(if its not working, the prob is related with the hardware issue. it has to be given for service
--if the prob is related with the software--
2. do system restore (all programs -> accessories -> system tools -> system restore)
3. try BIOS default
4. Update BIOS
5. Uninstall the drivers
6. restart
7.try system recovery
(if it doesn't work, its to be given for service)
let me know if it works
Jun 16, 2011 | Toshiba Satellite A40 Keyboard
Keyboard doesn;t work at all. Keyboard checks out OK at another PC
Is this a USB or PS/2 keyboard? If it is a PS/2 then the port that is integrated on the board is not working. If it is a USB, try plugging it into another USB port and see if it will work. If it does not work on either port then the ports on the system board are not working. It means u're having some malfunctions on the system board itself.
If it is a USB keyboard and it is that the USB ports integrated on the system board are not working, buy and install a PCI card with USB ports. It should work then.
Mar 15, 2010 | Dell 0Y3740 Keyboard
Acer aspire 1302 keyboard, touchpad, usb doesn t work
check with your keyboard works in Bios
please check with external key board
if it works ,then need to change the key pad
Mar 14, 2009 | Computers & Internet
Laptop Compaq Presario 2700 Keyboard & Mousepad lost at all
I read somwhere that most motherboards have a third layer of conductors laminated in the middle of board.It could be possible that you are shorting out something there. Take the screws out and try it without the heatsink for a minute or so. Most big DUI stores sell plastic screws in their hardware areas. These will work no problem.
Nov 28, 2008 | Computers & Internet
Keyboard?
WOW THATS A GOOD ONE. IS YOUR KB ERROR REPORTING ON IN THE BIOS SETTING? YOU WERE NOT ABLE TO INSTALL OS YET RIGHT?/
KB WORKS IN THE BIOS? BUT DOESN.T WORK IN THE OS SETUP?IS THAT CORRECT? XP?MOTHERBOARD?
YOU TRY F8? RETURN TO LASTYKLNOWN WORKING CIONFIOGS?
ARW YOUR KB PORTS ENABLED IN THE BIOS?I NEVER ENCOUTERED THAT ONE.TRY TO F8 IT.IF NO WORK GIVE ME MORE INFO.
Jan 28, 2008 | Compaq Presario 5000 PC Desktop
Dell POWEREDGE 2900  Server Logo
Alun Cox
