Question about Electrolux EI28BS56IB (278 cu ft) Bottom Freezer Refrigerator French Door
Error code 5y and ef
Error code and getting warm
Thanks Cindy, we had a repairman here, he did not look at the back of the refrigerator. He said the code meant we need a new control board for $475. I don't hear the fans blowing
Hello Troderka
Please keep all follow-up post in the original post by clicking COMMENT under the person you are addressing, in this case 'Cindy'. That way Cindy gets a notification and will assist you further. Plus all the great information is in the same post.
Your original thread is here.
have Kenmore 253 7041341B refrigerator with error codes 5y EF what does...
Andrew - Fixya Moderator
Jun 07, 2018 | Refrigerators
My Frigidaire refrigerator that is in our cold garage has an error code of 5Y on the freezer side and EF on the frige side. What does this mean?
5Y ef means evaporator fan issue. Could be wiring to the evap fan as well.
From the site: "I had a 5y ef error and it ended up being the control board."
Here's a link to a really good video:
https://www.youtube.com/watch?v=gCRKLkk9HmA
Hope this helps:)
Jan 01, 2018 | Frigidaire Refrigerators
My error code says 5Y on freezer and EF on frig? What does this mean?
This error code is most often linked to a defective evaporator fan motor. This is the fan located in the freezer, behind the back wall.
Jan 01, 2018 | Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Error codes 5Y EF
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 28, 2016 | Electrolux IQ-Touch 27.8 cu. ft. French...
My refrigerator is not keeping temp and there is a code on the water/ice machine reads S(or 5)y EF. What does this code indicate?
If I'm not mistaken EF error code stands for Evaporator Fan which is the fan motor in the back of the freezer section. That would explain the noise you heard. The fan could possibly be frozen or stuck or the motor actually went bad and needs replaced. Without that fan running you will get very little cooling.
Apr 15, 2015 | Refrigerators
What do the error codes 5Y and EF mean
Hello Friend, thank you for allowing me to assist you!
If you are getting error code SY EF, it typically indicates that your refrigerator has detected a failure with the evaporator fan circuit. Let's try resetting your refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is good wait approximately ten minutes and then turn on your refrigerator. If the error code does not clear, at this point it is best to reach out to professional to check the wiring between the main control board and evaporator fan. Hope this helps! - Z
Jul 19, 2014 | Frigidaire Professional 27.8 Cu. Ft....
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
What is code 5y and ef
Hi M - I am happy to assist you! Error codes SY/EF is commonly refer to a failure with the evaporator fan circuit. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, then more than likely there is a potential wiring failure between the main control board and evaporator fan. In this regard, I would personally suggest to reaching out to a repair tech to further evaluate and repair you appliance. If you have further questions, please do not hesitate to reconnect.
Jul 18, 2013 | Frigidaire FRS26H5AS Side by Side...
Electrolux EI28BS56IB (278 cu ft) Bottom Freezer Refrigerator French Door Logo
18 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
