Question about GolfBuddy World GPS
Will knot allow to turn off using touch screen
Woun,t turn off using touch screen
How do I make a knotless knot
I assume your using wire cable. Termination ends are available and a special set of pliers are required.
Sep 28, 2014 | Fishing
We're is the LCD located in my phone
One of the iPhone's greatest features is its highly intuitive touch screen.
Unlike other electronic device touch screens, your iPhone doesn't operate using the blockage of light to decipher which keys and commands you're pressing.
This makes it a viable choice for cell phone users who may not be able to complete other types of commands.
While you cannot alter the sensitivity of your iPhone, you can toggle certain features that make your phone easier to use.
How It Works
The key to understanding the sensitivity level of your iPhone's touch screen is first understanding how the touch screen actually works.
Instead of detecting light blockages or heat to interpret your finger's movements, the iPhone actually has a grid that lies underneath the surface of the touch screen.
When your finger touches the screen, electrical impulses detect the area on the grid that you're touching to interpret the letter, command or motion you're making to issue the correct response.
Screen Sensitivity
While previous models of the iPhone did offer the ability to change the screen sensitivity and the speed by which your phone responds to commands, the iPhones 4 and 4S no longer offer the option.
Instead, the touch sensitivity on newer phones is automatically calibrated for the fastest speeds, which means your phone responds quickly to your touch.
If this frustrates you and results in commands and calls you didn't mean to make, locking the screen by pressing the button on the top right-hand rim of the phone helps stop unwanted commands.
Assistive Touch
Update iPhones running on iOS 5 with an option known as "AssistiveTouch," which allows users who may not have complete control over their bodies and motions to use the iPhone.
This program allows you to change the speed at which the phone responds to your touch.
By tapping the "General" icon, then touching "Accessibility" and "AssistiveTouch," you'll enter the assistive touch menu.
When you turn on the option, an overlay appears on the screen that allows you to give commands by touch, rather than by shaking, swiping or pinching the screen.
When setting up AssistiveTouch, you'll have the opportunity to select your command tracking speed, which deals with how sensitive your iPhone is to your various gestures and custom commands.
Case Issues
Your touch screen isn't the only place where your phone is sensitive to movements.
Your iPhone has a feature called a proximity sensor.
The role of the proximity sensor is to sense the closeness of your face during a phone call. When the phone senses that your face is close to the phone, it locks your screen to prevent you from accidentally activating the touch screen with your cheek or ear.
This is handy, except when the proximity sensor is partially obscured by a case and is no longer sensitive to the position of your face.
The proximity sensor is found on the upper right-hand corner of your screen, so ensure that it remains uncovered to preserve its sensitivity.
http://www.gadgetvenue.com/how-the-iphone-touch-screen-works-02223447/
http://www.appleinsider.com/articles/11/07/11/inside_apples_ios_5_assistive_touch_allows_accessible_gesture_commands/
Jul 14, 2013 | Cell Phones
Screen is frozen cannot use the touch screen or turn it off
Push and hold the on/off switch. OR, Pull the AC plug and allow the battery to drain. If it is under warranty, return it or replace.
Dec 28, 2012 | Computers & Internet
My Kenmore 19001 touch screen works when I am sewing regular stuff, but when I put in the embroidery card - I can see the designs on the touch screen but nothing happens when I try to go to a design. I...
to recalibrate the machine press the stop/start; the reverse; and the knot button at the same time and while holding it down turn the machine on.
Sep 28, 2012 | Kenmore 19001
Is there a trick to rewinding a new recoil rope on a Tecumseh 4 stroke so that it rewinds properly and tightly?
It's not too bad, but it takes patience. Determine the desired length of the pull cord. You normally do this by placing as much of the old rope together as you can and then measuring it. Obtain the proper diameter line from your dealer, or a big box store. Put a knot in one end of the pull cord, and make sure that the other end isn't fuzzy, as you will be threading that end through the reel and shroud hole. An easy way to prep the line is to light the end with a lighter until it melts, then touch it to something and then pull it away slowly. This will leave you a fused end with a taper on it. Remove the shroud. With the shroud off, wind the reel tight. While holding the reel under tension with one hand, thread the tapered end of the line through the reel and out the hole of the shroud. Pull the line all the way through, and seat the knot. Place a knot about 6" from the end on the tapered end that you passed backwards through the shroud. If your pull cord passes through an eyelet on the handle, away from the shroud, thread the line through this before tying the knot. Slowly, release the pressure that you've been holding on the reel, and allow the reel to feed in the pull cord. The knot will not allow your line to be retracted fully into the shroud. Install the handle, and untie the knot in the line. Reinstall the shroud onto the machine.
Hope that this was helpful. You may rate this solution, if you like.
Best regards, --W/D--
Jan 25, 2011 | Tecumseh Enduro Horizontal Engine 5 HP...
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
My lawnmower starter pull rope broke and i wanted to replace it myself to the something i can do myself. It is a craftsman 7.0 horsepower push lawn mower. Any body with step by step instructions and what...
The biggest thing you need is time. There are no special tools required but it sure helps of there are 2 people available to perform this task.
You will have to remove the recoil assy if it can be removed without the air shroud or the entire upper engine cover / air shroud with the recoil. This procedure should be performed by 2 people that are NOT distracted.
First you will have to have a replacement rope. Burn the end of the new rope your going to install into the spool and pinch it so that the end is smaller than the rope and pointed. Install the pull handle on the new rope and make sure there is a good single knot on the end of the rope that goes into the pull handle.
Next you will have to remove all pieces of the old starter rope.
Then you have to pre-wind the spring of the recoil so that if you were to allow it to turn, it would turn in a direction that would pull the starter rope onto the recoil spool.
NOTE: Once the pre-wind is done if anyone lets go of the spool it can DAMAGE the recoil spring!
When your prewinding... Turn the spool until snugs and does not want to move anymore. Then back off the spool until the rope KNOT hole is aligned with the recoil rope guide.
Thread the new rope through recoil rope guide and into the KNOT hole in the spool. (Ice pick scribe jewlers screwdriver... will be required to pull the new rope up and out through the knot hole. Then TIE a KNOT in the bitter end of the rope and pull the knot into the knot hole on the spool.
FINALLY have 2nd person release the spool and it will rewind onto the spool.
Install the recoil / air shroud.
Thanks for using FixYa.
Kelly
Feb 28, 2010 | YouTube Videos
How do you replace the starter cord for lawn mower?
Hi and welcome to FixYa. I am Kelly
You will have to remove the recoil assy if it can be removed without the air shroud or the entire upper engine cover / air shroud with the recoil. This procedure should be performed by 2 people that at NOT distracted.
Then you have to pre-wind the spring of the recoil so that if you were to allow it to turn it would turn in a direction that would pull the starter rope onto the recoil spool
NOTE: Once the pre-wind is done if anyone lets go of the spool it can DAMAGE the recoil spring When your prewinding... Turn the spool until snugs and does not want to move anymore. Then back off the spool until the rope KNOT hole is aligned with the recoil rope guide.
Thread the new rope through recoil rope guide and into the KNOT hole in the spool. (Ice pick scribe jewlers screwdriver... will be required to pull the new rope up and out through the knot hole. TIE a KNOT in the bitter end of the rope and pull the knot into the knot hole.
Kelly
Jan 20, 2010 | Poulan "Poulan" Push Mower
My chicken is not turning in the rotisserie and i don't have a manual
DO not use a chicken larger than 5 lbs. Tie cooking twine around the chicken to hold it together so it doesn't touch the sides. I use two or three pieces of twine - wrap it around and tie - cut off the ends of the twine close to the knot.
Nov 19, 2009 | George Foreman GR82
GolfBuddy World GPS Logo
52 people viewed this question
Top GolfBuddy GPS Experts
ka4iup
ka4iup
Thomas Perkins
Thomas Perkins
Are you a GolfBuddy GPS Expert? Answer questions, earn points and help others
