Question about Sears Parts Direct Filtr-pump - 9742968
Clean scrren 9742968
How do I disassemble this assembly to clean the screen
HOW TO INSTALL PUMP FILTER PART 9742968
Do these two steps first:
25560288-xxcgpmvxnqk1u1vs0ulxqbhq-2-2.jpg Then remove the 6 screws around the sump and then remove the screws holding the screen filter on. Assembly is the reverse of dis-assembly
Mar 12, 2015 | Whirlpool Dishwashers
While Mitsubishi is off, have spots between inter-projector screen and outer
yes you can disassemble the front screen assembly to clean any spots dont use windex or streaking will result just a damp soft cloth then dry
Jan 02, 2013 | Mitsubishi WD-57733 57" HDTV
Check LInt Scrren Light is On and will not power on
The lint screen is so clogged the dryer will not run until the screen is cleaned
Sep 23, 2012 | Kenmore 6.7 cu. ft. Electric Dryer
On screen will appear white spots.
Clean the lens inside and out (but do not disassemble the lens assembly), and clean the internal LCD panel.
If this doesn't help, then the LCD may have defective pixels.
Jun 18, 2011 | ViewSonic PJ402D DLP Projector
1) how to clean the lens of camera? dust went inside display how to clean it?
Lens can only be cleaned outside on the front surface. Use T-shirt washed with detergent then dried, never rinsed. otherwise you have to change the lense assembly, in front of the sensor. That is a big job.
Display is lcd in front of LED light screen. You can clean between led screen, lcd and also casing screen using cotton T-shirt material, after you disassemble the camera.
Nowadays, digital cameras are disposable, not worth fixing. Buy a new and better one soon.
Mar 19, 2011 | Kodak EasyShare M530 Digital Camera
Whats the solution when tv dont display clear scrren?
yes it will work.first put 2 to 3 drops of water on screen and clean using a soft dry cloth and clean the screen from middle to the outer edges.wipe it clearly don't leave any water on surface.after that you screen just as looks as a new screen
Feb 13, 2011 | Televison & Video
Where is the fuel pressure regulator on a 99 gmc suburban 2500 7.4l v8
5.7L And 7.4L Engines
  1. Disconnect the negative battery cable.
  2. Relieve the fuel system pressure.
  3. Remove the upper manifold assembly.
    NOTE If the fuel pressure regulator is to be reinstalled, inspect the filter screen (if equipped) for contamination. If the filter screen is contaminated, replace the regulator.
  4. Disassemble the fuel pressure regulator snap ring retainer.
  5. Disassemble the regulator assembly and the O-rings.
  6. Discard the O-rings.
    0996b43f80205553.jpg Fig. Fuel pressure regulator
To install:
  1. Lubricate the new O-rings with clean engine oil.
  2. Install the backup O-ring, the large O-ring, the filter and the small O-ring.
  3. Assemble the regulator with the vacuum tube pointing down into the snap ring retainer.
  4. Install the upper manifold assembly.
  5. Connect the negative battery cable.
Good luck
Mar 02, 2010 | 1999 GMC Suburban
Lcd tv screen splotches
I have the same kind of problem. Sorry this is not a soultion but at least you are not alone!
Jan 25, 2009 | LG RZ32LZ50 32 in. LCD Television
No manual, how disassemble for cleaning;miss platform/extra blade
I just posted this info on an earlier question.
Here's the link to the owner's manual (PDF) you can save or print.
http://www.powerjuicer.com/pdf/express.pdf
FROM THE TABLE OF CONTENTS
Important Safety Information
Helpful Hints
Parts List
Assembly
Disassembly
Cleaning Your Juicer
Troubleshooting
Jan 20, 2009 | Jack Lalanne Power Juicer 250 Watts
Sears Parts Direct Filtr-pump - 9742968 Logo
212 people viewed this question
Top Sears Parts Direct Dishwashers Experts
Are you a Sears Parts Direct Dishwasher Expert? Answer questions, earn points and help others
