Question about Braun Home
Changing farenhigt to cesiousn
How to change farenhigt to Celsius on braun fht1000
Change temperature setting on Forehead Thermometer
no I contacted customer service, this thermometer reading ONLY in F, there is no option to change it to C
Jan 25, 2014 | Braun Home
Forehead thermometer fht1000
hola, quisiera saber como le puedo cambiar a mi termometro para q mida en celsius, es el termometro forehead de braun FHT1000 gracias
Sep 29, 2013 | Braun Home
I would like to change my ThermoScan from Celsius to Fahrenheit but I am not sure what buttons to push to achieve this
Changing the temperature scale from F to C: - - Turn on the thermometer - If the unit is already on, make sure it is not in the memory mode - Press the ?/MEM button and keep it pressed. Then press and release the activation button to switch over to the "change temperature scale" mode. - By pressing the activation button again, the opposite scale will be activated. Each further pressing of the activation button rotates the measuring scale
May 06, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Have a braun thermoscan and want to change it from F to C degrees lost manual
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
May 16, 2010 | Health & Beauty
Home Logo
Top Braun Home Experts
 Adam D
Adam D
Level 1 Expert
Karen Lynn
Karen Lynn
Are you a Braun Home Expert? Answer questions, earn points and help others
