Question about Hydrofarm Inc Hydrofarm Light Track System
Light track wont reverse
Stops in one place
Car wont move in drive or reverse. it tries but stops
does it make a sound grind or clunk and does the car shut off when this happens.
Jul 07, 2014 | 1999 Ford Taurus
I put the car on the track and put in my controller but it won't advance
One car on track runs great. When I place second car on its track, it stops. I tried to interchange cars. Both cars work on inner track. Both stop on outer track.
Feb 17, 2014 | Carrera Go!!! Nascar Electric Race Set
Bike turns over all lights on except the neutral light when i try and start it it wont start all fuses work battery good
You dont say what bike this is, most modern bikes wont start if the neutrol light does not work, this is safety feture to stop you starting the bike in gear, does the bike turn over ok or not? Does the bike have the gearing selection reversed as with rear sets in track mode as the gears are reversed, and neutrol would be 1 down from the top
May 05, 2011 | Yamaha NC 110 Motorcycles
It wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
Nov 20, 2009 | Philips CDR765 2-Disc CD Recorder
Reverse lights on 1994 Honda Passport wont work
I think the problem is in the shifter itself. Probably a bad contact after all of the years of use. If your real sneaky you could probably get inside the shifter and bend the contact point back into place.
Aug 15, 2009 | 1996 Honda Passport
Runs for a bit, then stops
Unfortunately the failure can be occuring in several places on this train. The wall power supply, the track command connector, the Treetop Tender or the loco itself.
The REALLY bad news is that New Bright does NOT offer any repair service or replacement parts for thier product. After the 60 day replacement warranty it either works or goes in the garbage.
However.. when the train stops, try taking a volt meter set to measure DC and place one lead on one the inside of the track and one on the outside of the track. You should be reading about 10.5V DC. (flip the leads if it comes out -10.5V)
If the you still have power on the track, then problem is in the treee top tender or the loco itself.
Look on the treetop tender between the wheels. there is an electric motor brush located between each of the wheel pairs. Make sure that they are making contact with the track. This is where the cars and the loco get thier power from the track.
These wear out pretty quick and once again, there are no replacements available.
May 28, 2009 | New Bright 384 Holiday Express Animated...
Lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Dec 17, 2008 | Lionel New Haven Freight Train Set
The motor is working good one way but when reversing the motor stops
You might get lucky with just a wire fell off. When you get to the motor, clean everything. The reversing must be controlled by the timer, back track all motor wires to the timer, check for dust or any other junk in the timer. Compressed air cans are great.
Nov 24, 2008 | Dryers
Hydrofarm Inc Hydrofarm Light Track System Logo
76 people viewed this question
Top Hydrofarm Inc Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hydrofarm Inc Toy Expert? Answer questions, earn points and help others
