Question about Makita 6935FDWDE 14.4 Volt Nimh Cordless Impact Driver
Dismantle makita impact driver
Split the case
SOURCE: Makita 14.4V Cordless Impact Driver only works at high speed
Most cordless drill / drivers like this have electronic switchs which unfortunately would have to be fixed by a repair agent. Depending on it's age - make sure that you tell the agent that it never really worked properly, warrentys only cover parts that were faulty from manufacture and not wear and tear, so it may get fixed for free depending on the repair centre
Posted on May 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: disassemble , houseing makita Model 6935FD Cordless
I would recommend going to Makitatools.com and typing in your model number for a schematic. Basically all you have to do is remove the 4 screws on the front holding the gearcase and then remove all the other screws holding the handle halves together. Let me know if I can help
Posted on Jul 14, 2009
  • 384 Answers
SOURCE: Disassemble a Makita 6980FDWDE Impact driver
Sometimes fasteners are hidden under labels.
Posted on Jul 24, 2009
rynanlimpiad
  • 36 Answers
SOURCE: how do i take apart makita 12volt impact driver
check the L.E.D. and then replace it
Posted on Apr 21, 2010
  • 34 Answers
SOURCE: makita impact driver dead spots
Depends on model you have. There are 2 brushless models - BTD132 (14.4V) and BTD144 (18V) - both have big BL letters on housing. According to your picture, you have BTD140 which has brushes. When you open user manual, you can find section dedicated to changing brushes. In case it does not help, you migh want to check trigger. Juraj
Posted on Jun 08, 2010
Makita troubleshooting
deep discharge protection activated to protect batterie measure on accu says nothing about the neccesary amperage in this case.
Aug 18, 2014 | Makita BTD144 18Volt LXT LithiumIon...
What is causing my 3/4" Makita electric impact wrench to overheat and slow down
remove the back cover and use some lube that is safe for electric handtools
Jun 19, 2014 | Makita Impact Wrenches 3/4" Impact Wrench...
Makita impact driver wobble
Many of my customers that use this tool heavily have the same problem. It's usually the Hammer Case (PN 154590-6). The nose if the case is the bushing that holds the anvil in place and sometimes wears out of round. Rarely the anvil (PN 324432-0) wears where it passes through the hammer case so check that also.
Feb 20, 2014 | Makita 18V LXT Lithium - Ion Cordless...
Can't remove bit
Remove the ring clip which holds the chuck outer sleeve in place and take out the washer and spring, the outer sleeve should now slide off, under the sleeve you will find two steel balls in the holes of the driver shaft, remove them (use a magnet if they won't come out easily) you should be able to get the bit out now, if not clamp the bit in a vice and using a soft face hammer strike the end of the driver shaft to release the bit. Note: dismantle the chuck over a cloth in case the balls fall out so you don't loose them
Feb 02, 2014 | Makita 18V LXT Lithium - Ion Cordless...
I have a pear 6980, and it works just high speed and you can control the speed I wanted to know what can I do if I can fix it myself
The variable speed function is controlled by the switch. On rare occasions you can remove the switch, spray it with electronics cleaner and blow it out well to get it to work again. Usually you have to replace the switch. The switch for your impact driver is Makita part number 638326-6 and runs about $65.
Jun 06, 2012 | Makita 6980FDWDE 12V Cordless Impact...
Dismantle cant open
most have security screws, you need to get them to take it a part
Dec 04, 2011 | Makita 6935fdwdex 14.4v Impact Driver...
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Sep 13, 2010 | Makita HP1620F Electric Hammer Drills
Makita impact driver dead spots
Jun 07, 2010 | Makita 18V LXT Lithium - Ion Cordless...
Makita 6935FDWDE 14.4 Volt Nimh Cordless Impact Driver Logo
23 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
