Question about Liebherr KI 2440 Premium Refrigerator
How clean evaporatie pan refrigerator
Smells
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES.
YUCKY BUT VERY REAL
Jan 05, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Removing the water pan underneath the fridge.
You would hope it was accessible from the front, but no. You probably have to roll the fridge out, not breaking the water line, and get to the pan. You may have to remove the paperboard rear cover, usually takes a 1/4": nut driver. Vacuum out all the dust while you're back there.
Nov 26, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the drip pan on my frigidaire r134a refrigerator,,I need to clean it out but can't find it..I found a black part on back made of plastic but can't take out..
HI welcome to fixya The major mgf. use a pan that the compessor will set in the heat from it will dry up the pan. You can add vinegar to tray to kill any smells. I hope this helps.
Sep 20, 2011 | Randell 20072SC R-134a Refrigerator
I froze shrimp in ziplock bags and it leaked in the back of the refrigerator and in the pan and smells really bad. How can I clean it. I don't know how to get the pan out and my hand is small but I...
Hello, To clean the bottom of the refrigerator just remove the two bottom vegetable draws. Refrigerators inside don't have external drain (why, it would the number one place for contamination from mold). The only pan that could be there is the refrigerant coil condensation catch pan. You'll to remove the kick panel on the front below the doors or door. It just snaps in, Once you get the front panel off, clean up the front there will lent, leaves, maybe one of kids sock, everything collect this space. You can probably see the aluminum pan, also there might be a front tab to take the pan out. Sent me message back and I'll tell how to clean the back of the frig. Madam, you did give the make of your refrigerator. GB...stewbsion
Aug 25, 2011 | Frigidaire Refrigerators
Refrigerator smells horrible , but there is NOTHING spoiled in it.
You might have something smelly in the defrost drain pan. The easiest thing to do would be to take the back off the fridge and see if the defrost drain pan smells bad...if so just clean it out with soap and hot water. don't use anything too strong smelling to clean it though, you don't want your fridge to smell like bleach or pine sol.
Good Luck!
Sep 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
How do I clean my drain pan on my side by side refrigerator it smells
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
Aug 07, 2008 | Maytag MSD2656G Side by Side Refrigerator
Liebherr KI 2440 Premium Refrigerator Logo
109 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
