Question about Patriot Sd Memory Card 2gb For Polariod Camera Cpm-300 I532fbdl
Polaroid 300- no green light when turned on-only flashing red lights (3)
Where do I get one
My polaroid 300 camera wont turn on why?
Hi Sophie have u made sure there are fresh batteries in the camera and there is definitely film in there
Aug 14, 2014 | Polaroid 300 Instant Camera - Blue...
The Flash will not work
1. Turn on the camera.
2. Set the camera to Still Image mode.
3. Press the Flash button to cycle through the flash settings and select the one you need.
The flash range: 3 ft to 6.7 ft (1 m to 2 m).
To find Find Flash button, see user manual or download it here
http://lv.diplodocs.com/jim/POLAROID/A500-_E
Feb 15, 2009 | Polaroid A500 Digital Camera
I would like some help with my tv
My Polaroid TV 3211 TLXB (2007) was working fine, turned it off and now won't power up, volts on power supply are normal, red light is on. Control boxes are avaiable. Could this be the most likley problem and are they interchanable with other similsr sets. ? Thanks for any help
Feb 10, 2009 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Flash dosen"t work
My camera is Praktica DC5.0 megapixel. The green light comes on when i want to take pictures, but the flash doesn't work
Dec 17, 2007 | Cameras
Patriot Sd Memory Card 2gb For Polariod Camera Cpm-300 I532fbdl Logo
179 people viewed this question
Top Patriot Cameras Experts
Are you a Patriot Camera Expert? Answer questions, earn points and help others
