Question about Smart Technologies SMART Board 580 (SB580)
Smart board says it is searching for Computer 1 Computer 2 Video 1 Video 2
Model 2102. Has a blue screen and continues to search. Does not connect to computer. The light is green.
How can i do to connect my smart tv to my netflix account
Connect the television to the internet.
Go to the Smart Hub section of the television and Search for Netflix. The app is normally on the Apps home screen as so popular.
Open the Netflix App and log in.
videos on the link for various makes
connect my smart tv to my netflix account Google Search
Aug 07, 2017 | Smart Computers & Internet
How to fix a 47inch lg smart tv that only has sound and a blue screen
You didn't give the model number, some have separate boards for signal processing, that would be the board that is bad in this case. If there's only 2 boards, it's the bigger one that has problems. Get the model off the tv, and the numbers off the board and type them into your favorite search engine
Apr 03, 2017 | LG Televison & Video
White flashing light inside the screen 50lb6100 lg smart TV50 Class 49.5 Diagonal 1080p Smart LED TV 50LB6100
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 12, 2017 | LG Televison & Video
Samsung led TV model UN40H6203AF no picture no sound no backlights. Flashlight test shows letters on screen after pressing menu button. Standby light blinks 5 times after turning on.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 29, 2017 | Samsung 40" Black LED 1080P Smart HDTV -...
Samsung pn51d450 blue bar on screen
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 24, 2016 | Samsung PN51D450 51-Inch 720p 600Hz Plasma...
I have a Samsung un46f6300 smart tv, and the sound cuts in and out every other second. It happens when I stream videos via youtube, use my blue ray player or any other input devices. Even on the startup...
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Apr 10, 2017 | Samsung Televison & Video
My LG Plasma 50PK550 shows 1 or 2 vertical lines, 1 pixel wide, with bad color : black, gray, white and blue are correctly displayed, but Red/Green colors are not rendered. I suspect a problem of Chroma...
Your idea should be correct I assumes. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Screen-shots to defective plasma screen is given in detail with fault causes. You can compare it to that of your TVs' and can make sure.
Oct 20, 2013 | LG 50PK550 50 in. TV
Laptop connected to projector get initial message "no signal" then projector continually searches through video, computer 1 and computer 2 - what do I do?
Make sure that you have enabled the 2nd screen output from the laptop. It sounds like there is no signal at the input of the projector. You can check this by connecting a monitor to the 2nd output of the laptop. Often you have to press one of the function keys (F5 possibly) to enable the 2nd screen from a laptop.
Feb 01, 2011 | Hitachi Performa CP-RS55 Multimedia...
How do I get hooked up to the Internet on my wii??
1. Be sure that your Internet connection is running smoothly and the green lights are all up. If you have a Nintendo Wi-Fi connector, you need to have the software installed and your computer connected to the Internet.
2. Turn on your Wii.
3. Select Wii Options, which is located on the bottom left of the screen. This is the button with the Wii logo.
4. Select Wii Settings.
5. Click forward to the second menu screen using the blue arrow to the right.
6. Select Internet.
7. Select Connection Settings.
8. Choose an open connection, indicated by the word: "none".
9. Choose a wireless connection.
10. Determine the best option for you: Manual configuration or Search for an Access Point.
11. On Search for an Access Point, your Wii will search for a wireless network to connect to and will display a list of available networks. Networks identified with a closed padlock require authentication to join.
Jan 04, 2011 | Nintendo Wii Console
XP video audio driver
Need name and model of computer or make and number of M/board to do a search
Aug 17, 2008 | Compaq Audio / Visual Board (286170001)...
Smart Technologies SMART Board 580 (SB580) Logo
35 people viewed this question
Top Smart Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Smart Technologies Computer and Internet Expert? Answer questions, earn points and help others
