Question about e-on software Vue Pioneer
Vue 12 pioneer
My 2004 vie will shift into gears but want move what can I try please help!
VUE will not move - SaturnFans.com Forums
www.saturnfans.com > ... > Models > Saturn Vue > Vue Tech
Jan 8, 2010 - 11 posts - ‎9 authors
The owner says it will not move and it is the transmission that needs to be replaced. Itwill start and run but when in gear it will not move. Is this a ... 99 SL1 Manual won't go into gear
May 12, 2009
Car won't shift into drive...
Nov 12, 2007
More results from www.saturnfans.com
Saturn Vue Transmission Problems - Car Forums at Edmunds.com
forums.edmunds.com > Saturn > Saturn VUE
Jan 26, 2013 - 30 posts - ‎17 authors
Learn more about Saturn VUE at the Edmunds.com Car Forums! ... miles and transmission is stuck i can feel it go into reverse and move ,but not for .... within a few weeks it started popping out of 3rd gear and makes a grinding noice, .... this bolt until I already had done so, now, it will not shift from 2nd to 3rd. More results from forums.edmunds.com
Nov 24, 2015 | 2004 Saturn VUE
My vue is over accelerating as soon as i start it. changed the tps and it still happens.
2002 3.0 AWD...SES Light and won't accelerate - SaturnFans.com Forums
Mar 10, 2009 - 4 posts - ‎2 authors SES Light and won't accelerate Vue Tech. ... As in DRIVE it will not over rev when you push the pedal to the floor. ... Does any one have any ideas where I should start? ....2004vue, Vue General, 14, 07-16-2004 12:57 PM ... 99 SL1 Won't accelerate
Nov 25, 2013
slow accelerate 1st gear
Aug 27, 2012
shaking during acceleration - what is it???
May 9, 2010
If You Are Having Hesitation Problems on Acceleration ...
Apr 25, 2004
200 Complaints: 2003 Saturn Vue Power Train: Automatic ...
www.carcomplaints.com/Saturn/Vue/.../power_train-automatic_transmiss...
The 2003 Saturn Vue has 200 NHTSA complaints for the power train:automatic ... At 76,000 miles when accelerating to get on highway, the RPM's were roaring .... Car junked, waste of over $20,000, I can't believe there has been no recall. ... we think this problem makes this model a lemon from the beginning. ... Nov 192004 ...
Oct 30, 2015 | 2004 Saturn VUE
What station does the 12 cdx run on?
according to pioneer their are 12 FM frequencies (stations) they start at 87.9 mhz and go to 90.1 mhz (fm) in0.2 mhz steps select with your remote. and set station and enjoy your music.
Sep 23, 2012 | Pioneer CDX-FM1287 12-Disc CD Changer
I have a pioneer car radio and i am receving and error 12 message
I found the following information on Page 28 of the Pioneer manual for your DEH-P2900MP through the pioneer website:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/370967683DEHP2900MPOperationManual1027.pdf
ERROR-11, 12,
17, 30
Dirty disc Clean disc.
ERROR-11, 12,
17, 30
Scratched disc Replace disc.
ERROR-10, 11,
12, 15, 17, 30,
A0
Electrical or me-
chanical
Turn the ignition
ON and OFF, or
switch to a differ-
ent source, then
back to the CD
player.
I hope that helps
Jun 22, 2010 | Pioneer DEH-P2900MP CD Receiver...
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
No installation instruction for pioneer cdx-fm128
the manual is really same with cdx fm-1277. Just look at the 1277 masual it will help you.
May 16, 2009 | Pioneer CDX-FM1287 12-Disc CD Changer
12 volt power outlets not working
under the hood on the driver side
Apr 20, 2009 | 2004 Saturn VUE
My 60''pioneer plasma blinks 12 times after i turn it on
looks like 12 blue blinks is a communication with the Digital tuner error. pioneer had a software upgrade/fix for this in some cases, others might need a new digital tuner pcb. I would unplug all power, wait 5 min, plug in (wait1 min) and try it again. If it is software, it should hopefully work. Make sure you pull your cable card if you have one. If it still won't turn on, you probably need the digital tuner board = $200-500 repair. Pioneer is usually very helpful, I'm really surprised they didn't help at all.. They'll want model #, serial # and date of purchase.
Jan 31, 2009 | Pioneer PDP-6070HD 60 in. Plasma...
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Dec 01, 2008 | Pioneer DEH-1600 CD Player
Computers & Internet Logo
14 people viewed this question
Top e-on software Computers & Internet Experts
David Payne
David Payne
Are you an e-on software Computer and Internet Expert? Answer questions, earn points and help others
