Question about NEC Original RD443E Remote Control
Remote not turning my projector on
Was working. Now is not turning the projector on. Changed batteries.
Remote stopped working for Sony, ceiling mounted, projector. Batteries changed.
Try calling 1-800-294-3889 or visit their website at: www.ElectronicAdventure.com to buy a new Sony projector remote.
Perhaps they'll even offer a suggestion or two that may help troubleshoot and fix your particular remote problem...I have no personal or financial interest in the aforementioned business- just trying to help and pass on good info.
I also attached a youtube video that offers a coupon code should you need to buy a new one.
Feb 20, 2015 | Office Equipment & Supplies
My x6 infocus does not react to the remote control
sometimes there is a switch near the battery or on the bottom of the remotes to disable it. otherwise some projectors have an option in the menu that you need to turn on to be able to use the remote, it should be under IR options
May 11, 2012 | InFocus X6 DLP Projector
Our projector no longer recognises the remote. We changed the batteries thinking they had died but the remote still doesn't work even with the new ones.
Just to confirm if the remote is working you can do a simple test. Take the remote very close to a working AM radio tuned halfway ( 800 - 1000kHz ) make sure there are no active radio station on that tuning, turn the volume up high. Press any button on the remote and one should hear some bleepling sound as if in an alien movie. If so the remote is transmitting OK. If not replace the remote. Did the previous battery leak and damage the inside ??
Mar 08, 2011 | BenQ Projector Remote (PB6110 PB6210)...
I have a ViewSonic RC00136P remote control. It
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Mar 29, 2010 | ViewSonic Televison & Video
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
Our Proxima DP5800 will not turn on with remote
First check the main switch located at the rear of the unit next to the power socket.Make sure it's turned on. Next, if the projector turns on with the power button on top of the unit, then the problem is with the remote. Replace batteries to make sure fresh ALKALINE batteries are installed correctly--the batteries must SAY alkaline on them. Ordinary carbon batteries WILL NOT WORK! Check inside the battery compartment for corrosion from a leaked battery. To actually test to see if a remote is working, you will need use of a camcorder with "night shot" or night vision capability. Turn on the camcorder and set it for night vision. From a distance of at least 8-10 feet, aim the remote at the camcorder and press a button...you will see the front of the remote light up as if it were a flashlight! That is the infrared coded light the remote produces to signal the projector.If you don't see any light, the remote is bad and will have to be replaced. If you see light, the receiver on the projector is not functioning correctly and will have to be repaired.
Sep 04, 2009 | InFocus Proxima Remote Control for DP5800...
The projector lock button has locked me out
this can only be solved with remote control or connect the AC cord while pressing the SELECT button on top.
this will cancel the control lock
Mar 06, 2009 | Eiki LC-SB20 Projector Multimedia...
Dead Unit
The projector bulb was burned out.
Jul 30, 2008 | Epson EMP-740 Multimedia Projector
Remote control for HP mp2220 projector
possibly it the remote controls battery that needs to be changed
Mar 11, 2008 | HP mp2220 Multimedia Projector
NEC Original RD443E Remote Control Logo
21 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
