Question about Pitco Frialator SG14 Deep Fryer
Flashing light light on temp control flashing, fryer will not try to light/ light that is flashing in next to a symbol appearing to be heat waves
Why wont the skin get crispy in the Butterball turkey fryer. We have tried everything.
element isn't getting hot enough. maybe only heating half way. need to replace element and or controller temp inside without food should reach 425 deg.
Nov 02, 2016 | Masterbuilt BUTTERBALL Indoor Electric...
B&S deep fryer heats up to set temp..like 170c, then pilot light turns off.try to relit,no good.if i wait10..20min.I can relit it.but when reach temp,flame goes out again.
The high limit is shutting the fryer off. It is auto reset and that is why the fryer works after waiting. It sounds like the thermostat is not shutting off and the high limit is kicking in. You need to check the actual temperature of the oil.
Aug 05, 2016 | Kitchen Appliances - Others
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Euro Pro F1066 keeps heating up well beyond the set temp. I can set the temp for 350 and it will go well beyond that temp.
I would try setting it for 300 and watch where it goes. If it goes above 375 turn it off. If it does it may be possible to calabrate the thermostat. If not replace it. I do not know this unit.
Apr 09, 2014 | Euro-Pro F1066 Deep Fryer
My xbox 360 controller dosent work!I have a black controller and a white one,the white one dosent trun on it just flashes like a freaking comilean!
There's a little button on the front of your 360 and the same button is on the front of the controller. You hit the button on the 360 and the green lights around the power button start to circle. Then you hit it on your controller and the green lights around thexbox guide button start to circle. In a second or two they'll find each other and both will flash at the same time, and it's synced up. I think there's a little symbol of air waves next to the button.
Try this it should fix your problem
Feb 28, 2011 | Microsoft Wireless Controller for Xbox 360...
I have a tefal family pro fryer, when i switch it on the green light comes on instead of the red and it will not heat up. why?
Look for a reset button on the unit, Push it, you will hear a "click' then the unit will work. If not, there is an electrical problem, the element, or temp control is bad.
Apr 11, 2010 | Tefal FR4008002 Pro Fry Deep Fryer
My Frymaster is beeping and coming up with a message HOT on the screen
Temp got to hot and shut down high limit. Also check for a broken wire to high limit
Sep 17, 2009 | Frymaster Dean H22 Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
Hobart Model#GF035A
The thermostat is acting up,The t-stat controls the heat,did you replace the pilot valve or gas valve?If there is 1 valve make sure the wires are in the correct terminals.
Sep 03, 2008 | Hobart 1HF50D Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
54 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
