Question about Sony LF-X1 12.1" LocationFree TV Television
Lfx-1 calibrate
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
Whst temperature do I set LG LFX 31945ST
Hey Rosalie,
The lower the temperature the better but do not operate to the extreme.
  • I would set the freezer between 0 and 7 degree F
  • The fridge between 34 & 37 degree F
  • Adjust Temp if necessary.
Here is a link to the fridge manual.
Good Luck!
JP
LG LFX31945ST Owner Manual
Jul 19, 2015 | LG Refrigerators
Spark plu gap setting for 2002 1.8 citreon Picasso Zsara
From 06/97; LFX (TU 7 JP(B)); 0.9 Gap
From 03/95; LFZ (XU 7.JP); 0.9 Gap
From 06/95; LFY (XU 7.JP4); 0.9 Gap
Oct 05, 2014 | Vehicle Parts & Accessories
Does emc for 2012 camaro v6 lfx have two gas tables & how do reset emc for premium
ECM. And no it does not. the fuel "table" is a timing calibration based on mechanical conditions, primarily valve timing and mechanical compression ratio. Simply reprogramming software doesnt change cam profiles or compression ratio and youd be doing more harm than good. The good news is most modern cars are smart enough to know if they are "pinging" or "knocking" from too low an octane fuel and make adjustments automatically. Go ahead and try going down 1 grade and if you dont hear noise by the 2nd tankful, you will be fine. Some engines are high compression or dont have sensors for detonation (knock sensors) and you wont get a change and must simply run the better fuels, but at worst, you finish a tank or 2 and switch back if the noises never gi away.
Mar 24, 2014 | 1995 Toyota Camry
Reset ecm for premium gas
you dont need to reset your ECM to burn premium gas, just add gas, over time the ECM will adjust to octane. May take a tank or 2.
Otherwise there is a fuse , read articel:
http://www.camaro5.com/forums/showthread.php?t=55114
Mar 24, 2014 | 2012 Chevrolet Camaro
REPLACE lg LFX 25971 LED LIGHT
I am having hard time taking the cover off. I am afraid it will break if I pinch it. is there a trick to it? what am I missing?
Feb 08, 2013 | LG Refrigerators
LFX 28978 LG French door refrigirator too warm, frost in the back of freezer
call for service, could be a computer board, fan motor, or defrost system. cheaper in the long run to call for service
Apr 30, 2012 | LG LFD25860TT Titanium French Door...
Upper body workout arms on Startrac 6230 crosstrainer are locked in the ''None'' position. How do I switch to ''Pushing'' or ''Pulling''?
You May have to recalibrate Here is the procedure
Engaging Maintenance Mode 1. Press and hold the , and keys together. 2. A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information window. 3. Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode The following keys are used to modify Maintenance Settings: Upper and Lower Data Information Window SCROLL keys: Display the next and previous settings. Increase and Decrease Level Keys: Adjust the value of the displayed setting up and down respectively, in increments of 1 unit. OK Key: Updates (saves) the value of the display setting in the Flash
Diagnostics - UB Calibration UB (Upper Body) Calibration (Elite Only) The UB Calibration will set the minimum and maximum range of the upper body arms in which they can move within. You can do a Manual Calibration or an Auto Calibration. Auto Calibration is recommended. To calibrate the Upper Body: 1. Enter the Maintenance Mode (see Settings – Maintenance Mode). 2. Press until UB Calibration is displayed in the information window. 3. Press to enter UB Calibration Mode. Manual Calibration 1. For Manual Calibration press 1. 2. Press the until the upper body arms stop moving (None Position), and then press to save. 3. Press the until the upper body actuator stops, and then press the to save. Auto Calibration For Auto Calibration press 2. The display will automatically raise the arms up, then bring them back down to calibrate the positions.
Mar 15, 2010 | Startrac Fitness Products Exercise &...
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
Sony LF-X1 12.1" LocationFree TV Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
