Question about Dishwashers
Whirlpool 8575637 I have no power going past the after the terminal box
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: whirlpool electric dryer
The following link explains how to wire an electric dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
This explains BOTH the three-prong and four-prong plug configurations, wire color codes, and the voltage readings. I hope this helps you. Let me know if you require additional assistance.
Posted on Nov 19, 2008
How old are the quiet partner II models, I have a 8575637. I would like to find a manual.
Try This you will need the model number.
http://www.whirlpool.com/manuals/
Jul 28, 2016 | Dishwashers
Whirlpool should be able to tell you if you ask.
Jun 20, 2014 | Whirlpool Gold 24" Tall Tub Built-In...
I have a whirlpool quite partner 2 model #8575637 and there is still about an inch of water in the tub and I cant get any of the buttons to work or turn on
I would check the simple solutions first. Make sure there is power to the receptacle its pluged into. If it's hard wired then make sure there is power by opening up the bottom, front panel and you will see the wiring compartment. There you will be able to check for power with a voltage tester. If no power then check all gfci receptacles and the breakers in your panel.
If power is on then you will have to replace either the main control panel or the entire washing machine in the worst case scenario.
Dec 12, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
I just purchased a du920qwdb4 whirlpool dish washer and there is no power cord. I looked all around it and I dont even see where on would go. Do you have any idea of where one would connect with the...
You need to supply a power cord; the power supply cord kit (Part No. 4317824), available at your local dealer or parts supplier, should be used, if you want to plug into a standard 3 prong outlet. Alternatively, you can direct wire the unit to the junction box. The wires connect to the dishwasher in a box that is behind a terminal cover that is held on by a screw. (It's on the back of the dishwasher at the bottom. You will also need wire nuts for 16 gauge wire and wire strippers. Twist the bare ends of the white wires together and secure with a wire nut. Do the same for the black wires. Loosen the front nut of the grounding connection stud at the back of the terminal box with a wrench (do not loosen the back nut). Wrap the bare grounding wire into a U around the stud and tighten.
For best results, thread the wires through a strain relief or flexible conduit connector (if you are doing direct wiring) and into the hole in the side of the terminal box. This will minimize the chances of damage to the wire. Then make sure the screws (for a conduit connector) or the strain relief are tight before you close the terminal box cover.
The manuals are available from Whirlpool: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?form_state=literatureSearch&context=&siteCd=WHRCOM&form_state=literatureSearch&searchTerm=du920qwdb4 . See the Installation Guide for details.
I hope this helps.
Feb 26, 2011 | Whirlpool 24 in. DU920QWD Built-in...
My whirlpool duet dryer will not put out heat. The tub turns. The lint is cleaned out after each use.
Thank you for contacting Fixya.com.
1) A burned out heating element. Remove tall box on right, element slides out from the bottom together with the "carrier". Look for broken coil, or check 2 terminals at bottom with ohm meter.
2) Burned wires at connectors. Check for obviously overheated wire terminals at all sensors (thermostats and thermal fuses in back), heater box, main terminals where power cord hooks up, etc.
3) An open thermal fuse. This is a small "thermostat" with 2 wires at the middle/top of the heater "box" (a tall narrow box on right in the back of the machine), or a plastic type on the duct close to the blower, depending on the model. You will need to remove the back cover of the machine to see these. Check with an ohm meter after disconnecting one of the leads, or jumper the 2 wires together to see if heater works (don't use this way though, fire hazard... replace the device) If this proves to be the cause of the problem, it would be wise to check all ducts and blower for excessive lint build-up. This will reduce air flow, causing overheating and blown thermal fuses.
4) Only getting 110 volts: This is often overlooked, but if for some reason one of the poles feeding the 220 power from the house wiring is open but the other is OK (for example, houses with fuses where only one fuse is blown, or a bad circuit breaker with one pole open). The motor and timer run on 110. If the side of the 220 line that feeds the motor is OK but the other one is open the motor will run but the heater, which 220 needs will not heat. Check for 220 volts between the 2 outer terminals where power cord connects or between the 2 "hot" terminals of the 220 outlet the dryer is plugged into.
5) Bad thermostats. There are usually 2 or more. A high limit on heater box, just above terminals on the bottom. 1 or 2 will be on the duct next to the blower. Check these with an ohm meter (or continuity checker). Some have 4 terminals; the extra 2 small terminals are small heaters inside the thermostats which alter its temperature characteristics. These will usually read around 4000 ohms or so. Check the 2 main largest terminals for continuity.
6) Bad centrifugal switch in motor. This is what actually turns the heater on, for safety reasons, so the heater cannot come on unless the fan is spinning. Otherwise without air flow past it, the heater would burn out.
There are 2 large gauge (usually red or yellow) wires going to the connector on the motor, these go to the contacts inside the motor that turn the heater on.
Also check the bellow link related to your issue:-
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have any further query.
Nov 30, 2010 | Whirlpool Dryers
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
Whirlpool electric dryer
Nov 19, 2008 | Dryers
2000 Ford Ranger
TEST B: BATTERY VOLTAGE OUT OF RANGE - DTC B1676
1. Check if vehicle has been jump started within past 2 weeks. If vehicle has been jump started, ABS is
okay. If vehicle has not been jump started, go to next step.
2. Using DVOM, measure voltage between positive and negative battery terminals. If voltage is 9-19 volts,
go to next step. If voltage is not 9-19 volts, diagnose charging system. See appropriate GENERATORS
article in STARTING & CHARGING SYSTEMS.
3. Turn ignition off. Disconnect 25-pin ABS control module. Install EEC-IV 60-pin Breakout Box (014-
00322). Turn ignition on. Measure voltage between breakout box terminal No. 20 and ground. If voltage
is more than 10 volts, go to next step. If voltage is less than 10 volts, repair Light Blue/Pink wire between
ABS control module and instrument panel fuse panel.
4. Turn ignition off. Measure voltage between breakout box terminal No. 25 and ground. If voltage is
greater than 10 volts, go to next step. If voltage is less than 10 volts, repair Red wire between ABS
control module and power distribution box/engine compartment fuse box.
5. Measure voltage between breakout box terminal No. 9 and ground. If voltage is greater than 10 volts, go
to next step. If voltage is less than 10 volts, repair Yellow/Light Green wire between ABS control module
6. Measure resistance between breakout box terminal No. 8 and ground. Also, measure resistance between
breakout box terminal No. 24 and ground. If both resistance measurements are less than 5 ohms, replace
ABS control module and repeat self-test. If either resistance measurement is greater than 5 ohms, repair
suspect Black wire between ABS control module and ground distribution.
NOTE: DTC B1676 will set if vehicle has been jump started.
2000 Ford Ranger
2000-01 BRAKES Anti-Lock - 4WAL - Explorer, Ranger & Mountaineer
Jun 11, 2008 | 2000 Ford Ranger SuperCab
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
