Question about HEWLETT-PACKARD Hewlett Packard Photosmart eAllinOne D110a AllInOne InkJet Printer
Page range i can't get current page printed
I can't get selection either
How do I print from 84-104
If you use the print dialog in Windows 7 & MS Word 2010 or 2013, then you will see the settings area "Print custom range". You can select individual pages by typing single numbers separated by a comma eg: 1,3,5; or you can select a range of pages eg: 10-20, 84-104.
This ability to print selected pages and ranges of pages is a common feature available to most programs written for Windows operating systems.
Jan 31, 2015 | HP Office Equipment & Supplies
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Xp word 2002 will only print first page of 4 page document
Be sure to select PRINT ALL instead of PRINT CURRENT PAGE
Jan 22, 2013 | Office Equipment & Supplies
I have a pixma mp630 and i want to print just one page from multiple page in a document how can i do it?
Move the cursor to the page you want to print. Then click File - Print then in Page range select Print Current page - then click OK to print.
May 04, 2011 | Office Equipment & Supplies
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Prints a page then a blank page
samlabbe,
First I would go to the lexmark wesite at http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_X5150&segment=SUPPORT&userlocale=EN_US#1
and download and install the latest driver. It may require uninstalling the current driver. The newest driver will have any updates and corrections and may solve your problem. Even if this is not the problem it can't hurt to have the most current driver.
If this doesn't solve your problem, when you are ready to print do a "print preview" which will show the layout and how many pages you are going to print. If it shows two pages (one being blank) see if there are extra spaces at the end of your text which is causing it to spill onto another page. You can also reformat the page with narrower headers and less margin which should allow your text to fit on one page. This can be done by selecting "page setup" under the "File" header. The default for most printing has very large margins/headers and they can be reduced.
The last change you could make would be to choose a smaller text to fit all the information onto one page. Additionally if none of the previous solutions work when you print, a window will open, called "page range", which allows you to select the pages you want to print . You could either choose "current page" or click on the bullet for l"pages" and type "1" in the box. This will limit the computer to printing only the first page.
Thanks for using FixYa and for the Great rating.
hardrocko
Aug 03, 2010 | Lexmark X5150 All-In-One InkJet Printer
Unable to stop printing
did u check the box containing print CURRENT PAGE?????i guess u must not have done this
Oct 22, 2009 | Office Equipment & Supplies
I can print PDFs if I print from Preview (mac) but when I try to
You can try these steps and let me know the result.
=== Problem Printing from Adobe ===
1. Open PDF document.
2. Click on 'File' menu.
3. Click on 'Print'. Print window will open up.
4. Click on 'Advanced' button on the left bottom of the popup window.
5. Put a check mark next to 'Print as image'.
6. Click on 'OK'.
7. Select the 'Current Page' from the 'Print Range' option.
8. Click on 'OK' to print one page of the document and see.
=== Enable Background Services ===
Background Services to reduce the memory for printing issues from applications like Adobe, Power Point,etc.,
1. Click on 'Start'.
2. Right click on 'My Computer'.
3. Click on 'Properties'.
4. Click on 'Advanced' tab.
5. Click on 'Settings' under 'Performance' Settings.
6. Click on 'Advanced' tab in 'Performance options' window.
7. Select 'Background Services' for 'Processor Sceduling'.
8. Click on 'Apply', then 'OK'.
9. Click on 'ok' button on 'System Properties' windows.
Sep 28, 2009 | HP LaserJet 3600n Printer
Page range
hmm..bad drivers for sure.
remove them from control panel, add remove software.
go here, find Lexmark icon, and get new drivers for your model and operating system
reinstall and try it again
Apr 03, 2008 | Lexmark X2500 All-In-One Printer
HEWLETT-PACKARD Hewlett Packard Photosmart eAllinOne D110a AllInOne InkJet Printer Logo
10 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
