Question about Sunbeam Humidifiers
Sunbeam scm3755c will not run
It will not run. It is getting power. Motor won't run.
Wiring my HE300A1005 troubleshooting
Good. Wiring should remain stationary and not ambulatory.
Feb 16, 2013 | Honeywell HE300A1005 120v, TrueEASE, 18...
Faulty water level indicator
It is the reed switch inside the post that the float runs on, it gets corroded and needs to be replaced. It is an easy and cheep fix if you can get the reed switch. I would also suggest adding silicone as the factory seal is poor before you put it back together.
Oct 28, 2012 | Sunbeam Humidifiers
My sunbeam humidifier doesn't work
Do you mean Dehumidifier? A machine that takes the humidity out of the air. If this is what you mean and you hear the fan motor working with no water dripping then the problem is that the coil which holds freon gas has leaked out the gas and can be recharged again with the leak fixed of course. Depending how old the unit is you may be better off buying a new model. Repairs can be costly. Hope this helps!
Mar 26, 2012 | Humidifiers
My sunbeam humidifier model SUL 495 does not seem to be working right?
Is there a filter or strainer where the water is pulled up? if so clean it, also you can run some kind of decalcifying product through it like CLR, which is non toxic.
Dec 14, 2011 | Sunbeam Humidifiers
Have a aprilair 550 for some time. Installed a new Lennox G61MP furnace and the technitions failed to reconnect the wiring that powers the humidifier. Need wiring schematic. Does humidifier transformer get...
Hello, yes the transformer will get a 120 volts from the Furnaces control board, there should be a terminal labeled HUM on the control board. You need to bring 2 wires one from HUM and one from a nuetral tap on the board to the line side of the transformer, this way every time the blower motor on the Furnace turns on the humidifier will aswell.
Aug 23, 2011 | Aprilaire 550 Humidifier
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
http://www.hunter-humidifiers.com/manuals/34357.pdf
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
Hello! please advise what will happen if unit is left running & is out of water?
If the float valve in the water tank is not working properly, by shutting off the unit when it's empty, Leaving it running will probably burn up the pump motor.
Feb 16, 2011 | Sunbeam Health at Home Warm Mist...
The fan is loud and the motor is running "hot". Is there a place to oil the fan's motor?
This is a sealed bearing motor so there is no oil ports. You can blow out with compressed air and spray motor shaft with WD-40. Be careful not to spray any lube inside motor. If you can get to them blow out motor cooling ports .this should help motor run cooler and quieter. Hope this helps you. Thanks
Jan 02, 2011 | Essick Air Credenza 696 400 5.2 Gallon...
Humidifiers Logo
87 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
