Error Showing E2 on fujita ASW-H12A4/HS. What does this mean
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
SOURCE: I BOUGHT DAEWOO AIR CONDITIONER APPLIANCE AND I
Hello,You have 12,000BTU per hour or 1 ton unit.Hope that helps
Posted on Oct 30, 2010
hvac1960
  • 2133 Answers
SOURCE: we have just installed our
E5 Outdoor activation of compressor over heatprotection or motor lock
or E5Communication error between outdoor and indoor.
Please check input of out door unit and contacor coil energized. if no power input correct it. If no power in contator coil, mat be the problem PcB thermostat command. Check your setting is 23 dgree and less than that and also mode in "Heat".
Posted on Dec 16, 2010
hvac1960
  • 2133 Answers
SOURCE: My fujita air conditioner has
E-2. Indoor coil temp sensor defective. Replace it.
Posted on Dec 30, 2010
SOURCE: Error code E2 A.C. AUX
Disply E2 error Coming
Posted on May 14, 2013
My aircondition shows f6 error code starts outdor unit for few seconds and stops. Vox asw-h12a4/qb
Hi Marija, F6 error code is....I hope this helps.................CHEERS..
1?Check whether the resistance of sensor is normal, otherwise replace it.
2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 08, 2016 | Heating & Cooling
HOW I CONNECte remote control to fujita air ASW-H18B4/HS
If it the correct remote control for the unit, point remote to unit and press power button this is normally followed by a beep to confirm unit has received command,
if this does not work please check battery's to ensure they are still fit for purpose
Dec 24, 2015 | Heating & Cooling
Fujita remote control code for air conditioner model ASW-H12A4/HS
06,03,09,01 are the codes to check. If you wish to get more, check these links. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Selecting the view option, either to Mosaic / Timeslide, can be selected by the dropdown list, at the top left of the display window, it will make surf easy.
Oct 09, 2013 | GE JASRM24912 Remote Control
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
We have just installed our 1.5kw split system model no: ASW-H12A4/SQCR1DIAU - error message comes up as E5
Dec 16, 2010 | Heating & Cooling
My washing machine is SANYO ASW-90WRTP. It cannot spin and showes E2 on the screen. I guess it means Error 2, but I don't know how to solve the problem. Thanks.
mungkin
  • barangkali
  • agaknya
  • ')" onmouseout="ht(this)">perhaps
    pintu
  • daun pintu
  • laluan
  • ')" onmouseout="ht(this)">door
    tidak ditutup
  • tak bersalut
  • ')" onmouseout="ht(this)">uncoated
    dengan betul')" onmouseout="ht(this)">properly or penapis
  • tapis
  • menapis
  • ')" onmouseout="ht(this)">censor
    in pintu
  • daun pintu
  • laluan
    gagal
  • kecewa
  • terkandas
  • ')" onmouseout="ht(this)">failed
    . menghubungkan
  • sambungkan
  • menyambung
  • ')" onmouseout="ht(this)">connect
    pendawaian')" onmouseout="ht(this)">wiring penapis
  • tapis
  • menapis
    with ( 2 dawai
  • wayar
  • kawat
  • ')" onmouseout="ht(this)">wire
    ) jika tiada
  • sekiranya tiada
  • sekiranya tidak
  • ')" onmouseout="ht(this)">if no
    dawai
  • wayar
  • kawat
    penapis
  • tapis
  • menapis
    menggunakan
  • penggunaan
  • gunakan
  • ')" onmouseout="ht(this)">use
    magnet
  • besi berani
  • batu berani
  • ')" onmouseout="ht(this)">magnet
    diletakkan pada')" onmouseout="ht(this)">placing at mengenai kawalan')" onmouseout="ht(this)">on control litar
  • lingkungan
  • peredaran
  • ')" onmouseout="ht(this)">circuit
    Nov 20, 2010 | Washing Machines
    Jul 23, 2010 | Heating & Cooling
    Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
    Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
    E2 error
    Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
    Jan 11, 2008 | Mitsubishi HS-U445 VHS VCR
    Heating & Cooling Logo
    41 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
