Question about Memorex MT2274 27" TV
How to get a full screen picture on MT2274 models
On dish net receiver unable to zoom a full picture
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Picture is much smaller than screen size Sony tv
Should be a botton on your remote that changes that..like normal...Zoom..Full screen.And if your useing a antenna sometimes the pictures not as big as the screen. Try a hd video and see if it plays full screen
Aug 13, 2013 | Televison & Video
When i save the picture that received from mms, i was not full to the screen... what should i do? in the setting i already set it on 1600 x 1200... but the picture i received still small....
you might have to enlarge it before you send it at the right size if you are unable to enlarge it once it has been received on your phone
though some mms message can only be sent at a certain size
hope this helps
Nov 12, 2011 | Nokia 5130 Cellular Phone
How to format my PHILIPS flat screen. I want the picture to be full screen
On the picture menu, you can select between 16:9, 4:3, zoom 1, zoom 2, etc. Depending on the station you are watching and whether or not it is an HD station, selecting zoom 1 or zoom 2 on your TV remote might give you full screen. Otherwise, on some DISH remotes there is a format or zoom button that will also change the size of the picture.
Feb 27, 2011 | Philips Televison & Video
Tv picture is always on full screen can not change it to wide screen or small screen. so side of picture is cut off so miss half off people at either side of screen and logos too tv channels missing like 5...
Do you use a satellite dish or cable? There are 2 different ways to control picture size. One is through the TV itself but there is sometimes also a control through the dish. For DISH network it is format on the remote. You may want to check if that setting is set to zoom or a setting like that. If it is, the TV control of the picture won't change anything. Email me back with more details if this doesn't solve your problem.
Feb 20, 2011 | Televison & Video
When channel guide is up picture runs good but when go back to full screen the picture lags about 15 to 20 sec.
Hi mike7212001my name is Mike Houston of DISH Network and I was going over your postand seen where your receiver when full screen is running 15 to 20 secondsbehind. The first thing you will need to do is unplug the receiver for 10seconds and let it power back up and require the signal and download theProgram Guide. If the problem is still happening press the buttons ofMenu-6-1-1 and select Check Switch. Then select the Test button and after thetest completes exit out of all menus and the receiver will require the signaland your programming will be in sync.
Feb 20, 2011 | DISH Network ViP 211 DTV Receiver
I have changed the screen size to 16 x 9. There is black space at the top and bottom of the screen. What do I do to correct this?
Hi welcome to Fixya,
Presently there are 16 formats (sizes) transmitted and you may need to hit a button to show a full screen sometimes on some channels. The format , aspect or size buttons are on both the TV remote and any cable / dish remote you have . set the TV to full or 16x9 if using a cable / dish box, then set the box to the stretch mode and the picture should be full, there may also be a zoom setting that will fill the picture but may cut off the edges.
Respond with more details or try the suggested settings
Thanks
Roety
Aug 03, 2010 | Panasonic Televison & Video
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Aug 24, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
Menu button won't work
The codes that are provided to operate the tv from a Dish remote will not offer full functionality with most TV's. The menu button on the Dish remote even when able to bring up the menu screen on TV's is unable to navigate the menu screen due to the complexity of the TV's set up. The newest receiver that Dish has on the market is the 222k which is a dual tuner/two room HD receiver without DVR that has LEARNING REMOTES that might be able to accomplish the goal you are trying to obtain. I hope this answers your question and remember to keep the original TV remote in a safe place so that you can use other functions on your TV as well. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 12, 2008 | DISH Network IR Remote Control
Memorex MT2274 27" TV Logo
11 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
