Question about Kenwood Excelon KVT815DVD Car DVD Player
I have a dodge carevan 2004 i cant turn on dvd player to watch movie
Dvd player wont turn on
My PC wont play album I requested.
You only need compatible dvd player software to listen to movie dvd disks. For playing standard audio cd disks, nothing is needed since this support comes built in-to the OS, (Windows XP or higher)
Apr 24, 2014 | Computers & Internet
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
My asus dvd burner will burn the movis but i cant watch it in my dvd player. but other burnt movies i can
use from dvd burner to putting some special files that need for dvd players.only write your movies on movie mode!
Jun 24, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Mine wont play anything a DVD it recorded it wont let me finalize
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jul 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
May 31, 2009 | iLO 3200 32 in. LCD Television
Pioneer dvd r/rw wont play a dvd
If your computer recognizes a disc in the drive and operates normally, Id assume you would need a DVD player or codec to be able to actually watch the DVD. PowerDVD rings a bell.
Have you tired that? I know Windows Media Player by default wont let you watch a movie without first downloading a codec.
Mar 19, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Cant get rid of closed captions on dvd player
go to menu turn off captions thank you for using fixya
Feb 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Changing dvd region settings on LW60 laptop
0 means the region is perfect you can play all dvd regions.
This is what you would want if you're going to watch NTSC, PAL, etc. movies.
Jan 24, 2008 | Computers & Internet
Dvd driver
are you trying to watch dvd's from a disk ??? unless you have a dvd player installed it wont work , example, power dvd installed ? here is a free dvd player you can download http://www.avsmedia.com/DVDPlayer/index.aspx after you install this you should be able to watch dvd's with this program, and media plarer 11
hope this helps
Nov 20, 2007 | Compaq Evo D510 Minitower (Open Box)...
Kenwood Excelon KVT815DVD Car DVD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
