Question about IBM Infoprint 1612 Express Printer
Ibm 1612 error
Cannot print
I was just driving one day and the car died and now it has no spark and no fuel i did also get a 1612 code
Make of car is needed for this, but points to an ECU failure if you have a Volkswagon..
Google
make 1612 odb error code
Or this is the best ODB11 Error Code site
http://obdii.pro/en/code/P1612
P1612 Engine Control Module Incorrect Coding
P1612 Engine Error Code
Dec 18, 2016 | Cars & Trucks
IBM 1612 prints out half of the page.
Hi
Just set up new printer with the same name and set it as default printer. Then delete the old printer icon. If it prints the test page, then it solves your problem. The printer driver is corrupted.
regards
Feb 20, 2011 | Office Equipment & Supplies
Error 1612 comes up with I try to update or uninstall. My PDF's won't print.
Try using the windows install clean up utility to uninstall adobe reader. Go here to download it http://www.geekstogo.com/forum/files/file/397-msicuu2exe/
After you install it, run it and erase everything that is adobe. After you do that try to reinstall the latest version of Adobe reader from Adobe's website and see if that helps
Aug 29, 2010 | Adobe Computers & Internet
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
Rip software code 900
Please contact the IBM Printer Technical Support for more exact information.
A 900 RIP error means that you have a down-level firmware build on the printer. Its a software bug that was more than likely fixed in later issues of code.
Normally all you have to do is download the newest firmware build and then follow the instructions to upgrade the printer.
Don
Nov 23, 2009 | IBM Infoprint 1612 Express Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Infoprint 1612 displays "maintenance" on menu
You can ignore it if you want, but you will likely see a deterioration in print quality soon, and myabe jamming Etc. "Maintenance" is on an internal electronic counter, and lights up when the life of the fuser, transfer roller, P.F. tires, etc are nearing the end of their lives. To ensure trouble free/ uninterupted operation, you should consider calling for service. The maintenance light can only be reset by a technician .
Mar 11, 2009 | IBM Infoprint 1612 Express Printer
Door handle for Equator EZ 1612 V
If you are still waiting for this part you can purchase it from www.appliancedesk.com click on shop parts.
Jan 23, 2009 | Equator EZ 1612 V Front Load Washer /...
IBM Infoprint 1612 Express Printer Logo
20 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
