No signal Tele has no signal
Looking for stand flat television 17" rld1730
sadly there is nothing we can do here on FIXYA about you needing to buy a larger stand for your television .
Aug 03, 2016 | Televison & Video
I have a binatone tablet and trying to connect to Samsung tele got cable but says no signal?
connect it and make sure, that you have chosen correct input.... so on remote press input button until you see tablet's picture
Apr 21, 2014 | Samsung Televison & Video
Ww skymediauk co uk
If you had another tele on the antenna circuit that you plugged in to the new set and that old set worked, take the new one back, it is a problem that you cannot fix.
Aug 31, 2013 | Audio Players & Recorders
Cant find buttons on back of tele
Usually Sony LCD TV has control buttons on top or at lower side of TV.
Let me know your TV model number to find out exact location of buttons.
Thanks.
Oct 18, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Laptop to samsung tele
  1. Ensure that the connection is a direct cable connection from the PC to the TV, no converters or cable adapters as these are generally not Bi-directional which is required for a PC to see a TV.
  2. Try turning on the TV, then booting the computer. Some devices require the initialization signal from the computer to activate the port on the TV.
  3. See if the TV input select has an option to search for active signals.
IF none of that helps, post the exact model of TV and computer as well as the type of cable connection you are using.
The biggest stopper most of the time is a cable converter.
Jul 08, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
