Is it possible for me to get a manual of the battery pack so that I know what each of the ports is used for. that is I would like to buy the battery pack to power outher things and need to know what e
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
With the battery charger lol I don't know if your scooter has the battery pack or not but if it does there should be a charger port located on the battery pack just plug the charger into the port and let it charge overnight. If it doesn't have the battery pack then there should be a port located on the tiller usually under the throttle levers Hope this helps
Well as you probably know all there is to a rechargable battery pack from xbox is 2 generic batteries that connect to the plate that connects to your controller. I recently took mine apart to try and fix it because it was not working at all. If you still have the original battery case that takes the AA batteries i would go out and buy a rechargable battery base and charge the cheap *** batteries that xbox uses in their packs. Then use the batteries that came out of the pack and put them in the original harness. Or you could just use the ones you buy.
It is a custom lithium-polymer battery that built just for this camera and I don't think you can order one from Che-ez anyway. But if you are savvy enough, you can re-build the battery by taking the old battery pack and the protection circuit board out with a soldering iron, keeping the plastic frame and replace the pack with a similar one that you can buy on ebay for less than US$10. Just search "Lithium Polymer 380mAh" and that is the one that gave mine a second life. WARNING: Do it at your own risk, don't hold me liable if you lose a finger or more from mishandling the potentially explosive Li-ion battery pack. Good luck!
You might remove the battery pack and try it on AC only; it's possible that the battery pack has died while it was not being used or recharged.
If it does work without the pack, you can choose to make a permanent 'desktop' unit of it or bite the bullet and buy a new battery pack.
If you buy a new one, shop the price; it can vary at least 2:1.
