Question about Acer Aspire Computers & Internet
Unable to read code on side of case to get into main hard-drive
Grandson has locked main system out
  • Acer Master
  • 1,087 Answers
I would get in touch with
http://www.acer.com/worldwide/support/
Posted on Mar 28, 2014
Replaced hard drive, computer isn't completely loading
If you replaced with a brand new HD then there are no files for the computer to read and boot from. You really have two choices, contact the vendor of the computer and see if they will offer you a set of the original installation disks. If not, you will have to go buy a new "operating system" set of disks ex: Windows 8 disks. You will not have any of the information you stored before as it was all on your old hard drive. However, in rare cases, a pulled hard drive that was unable to boot can be READ as an external drive. You can buy an external case for it and plug it into an operating computer and perhaps retrieve your files. You will not be able to transfer any programs. Just files like photos word processing etc.
Marty de
Mar 12, 2014 | AOpen ATX-300GU (9197020C77)
How to open the case of a my book wd 320gb
Sounds like the drive in the thing is shot or the controller itself.
I remember a friend having one of those I dont recall it having any screws but it did have a snap apart case. Use a thin flat head screwdriver to locate and snap apart the catches.
If you can get into the thing to replace the drive and get the same result then the controller is shot and you will not have any luck fixing it unless you are good at surface mount soldering.
For now, check that the cables are good and that you are connecting it to a good port on your computer.
It is not uncommon to have external drives go kaput for seemingly no reason. The drives they tend to use dont like to be moved AT ALL when they are powered on, this is not condusive to an EXTERNAL case as it is too easy to move around.
Good luck. Let me know if you have any problems getting it apart, I can look up my friend and take his apart, yea hes cool like that.
May 02, 2008 | Western Digital My Book (WDG1U2500)...
Tip
Reasons why Hard Drives fail.
A hard drive's file system may become corrupted or damaged due to a virus or software malfunction, but this is not a true drive failure because in most cases you can reformat the drive and reinstall the operating system and everything is back to normal. Hard drives fail due to a malfunction in their mechanical or electrical components.
The following picture illustrates the major components inside a hard drive:
The following is a list of the most common mechanical failures that can happen.
1. The spindle motor can malfunction. The spindle motor works much the same way that cd-rom or dvd player spindle motor works and is located in the middle of the hard drive platters. In a hard drives case, it's job is to spin the platters.
2. The read/write heads malfunction or the actuator arm malfunctions and prevents the read/write heads from reading the data stored on the hard discs (the platters). The picture below shows a closer view of the platters, actuator arm, and read/write head.
3. The hard discs themselves can become damaged by rough handling (dropped) or can in some cases become scratched by the read/write heads if they touch the disc.
4. On the back side of the hard drive case you will see where the cable and power supply plugs in and you will also see where the jumpers are. These contain small pins and can easily be bent or broken.
5. Another problem that can occur is the cables and ribbons themselves become loose and do not make a proper connection or the cable themselves can become damaged. The power cable can also become damaged or malfunction.
Picture of an IDE cable.
Picture of a SATA cable.
Hard drives can also fail due to malfunctioning or damaged electronics on their circuit board.
The most common electrical components to malfunction are Transistors, Capacitors, and Resistors. Power surges are the common cause of these small components to fail, so remember to make sure you are using a good surge protector or a UPS system for your entire computer system. A good policy is to always unplug your computer system from outlets when a storm is capable of producing lightening. It is also important to remember that if any of these failures happen, it will be cheaper to replace the drive for a new one. You can return a hard drive to the manufacturer to be fixed if it is still under warranty. Read your documentation and warranty information carefully if you purchase a new hard drive to upgrade/replace your old one.
The following picture is an illustration of where the hard drive is located inside the computer case. In this case, it is a SATA hard drive.
on Jan 10, 2010 | Computers & Internet
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
How do i remove write-protection from a flash drive?
Usually there is a tiny hardware switch, hidden on a side. Most USB keys do not have it, and some that do have it internally, unaccessible, and of course set to READ ALLOWED. If a hit moves it to READ ONLY, you'd need to pry open the key casing to access it.
Also, some "advertising" USB keys, presented to customers as 'electronic brochures', are filled with advertising material and the switch flipped (or soldered, in some cases) before the key is sealed. You can make these read/write with a judicious use of a paring knife.
Finally there are some more advanced keys with internal control software, allowing for encrypted storage, password protection, boot-from-usb and read protection. You need the manufacturer's USB driver or utility to be able to access these functions, though. The DaneElec zMate has a password protection utility (you'll find it on their website), but I have been unable to find it for your model. You may want to check yourself.
Apr 03, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Laptop unable to read hard drive in bios
Open your screw case of your hard drive under body your laptop , release or remove your hard drive, try change with normal hard drive, check if work your 1 st hard drive is broken , you must change with new one.
Sep 26, 2008 | Computers & Internet
Operating system
Most probable cause is that the pc is unable to detect the Hard Drive, could be caused by some loose connections/wirings. Open the CPU case and try to re-attach the cables from the motherboard to the hard disk drive, and try your pc again.
Jun 03, 2008 | HP Computers & Internet
D Drive / E Drive
try to cange cable if not buy new unit 20 bucks pop in easy they fail often thx nick
Feb 04, 2008 | Maxtor Hard Drive
Computers & Internet Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
