Question about Sony XAV-601BT
Have tried to fit this system but have no display
Have tried to fit this system in a 2012 Seat Ibiza but there was no display when all wires are connected
What is spring sign showing on dash of seat Ibiza sport 1.6
hi Marc
SEAT Ibiza glow plugs heating warning light - your SEAT Ibiza is equipped with an automatic glow plug system. The indicator lamp lights up while the glow plugs are preheating. If the engine fails to start immediately, the glow plugs have not finished preheating. In this case, keep the clutch pedal depressed (or keep your foot on the brake if your vehicle has an automatic gearbox) until the engine starts. (applies to diesel cars only)
Ibiza Mk4 dash lights
Apr 23, 2017 | Seat Cars & Trucks
Seat ibiza faults
Check alternator charge rate and earth straps
Jun 19, 2014 | 2007 Seat Ibiza 1.2
I need seat ibiza 1994 wiring digram
enjoy this link ;-)http://www.seatclub.cz/graphics/manuals/8/IbizaCordoba93-99ele.schema.pdf
Nov 10, 2012 | 2003 Seat Ibiza
How do i fit a brake light switch on 2003 seat ibiza 1.2
underneath your stearing wheel loosen the covers there and on the brake pedal above it 2wards the stearing wheel you will see it allocated above the pedal loosen the lock(nut) unplug the connected switch then screw it open an thats it
Oct 24, 2012 | 2003 Seat Ibiza
Front lights /indicators wiring colours /diagram for 2001 seat ibiza
We do no have this make in the USA so have no info on it. Sorry
Jun 10, 2012 | Seat Ibiza Cars & Trucks
Seat Ibiza 1.4mpi cuts out completely whilst driving and will only restart after a 10 min rest! First started cutting out after around 15 miles now it's ever 1 mile.Any ideas??? (new coil pack fitted with...
Hi Robtatt.
I have same problem with my seat ibiza for the past 6/7 months, spent over £300 on trying to sort it out and got no-where. I think i have now finally sorted it. Try un plugging the lambda sensor from the exhaust just behind the engine. If like mine it works fine but the sensor will have to be replaced. Good luck hope this works for you.
Johno 67
Mar 22, 2010 | 1999 Volkswagen Golf
How to reset service light on a 58 plate Seat Ibiza. Car has had full service and was not prepared to pay Seat dealer double but what they tell me is its a two second job, but will not tell me how to do...
Dealer would simply reset using diagnostic and charge you for it
Here is manual reset
Switch ignition off
Press and hold trip button left off speedo
Switch ignition on
Service will appear in display
Release trip button
Turn trip button to right untill [-] appears
Release trip button
Switch ignition off
Feb 03, 2010 | 2008 Volkswagen Jetta
My stereo and display is not working in my seat ibiza 1.9 sdi w reg 2000 the display also shows you the heat and speed you select and the clock, the heater controls still work.
Check the fuses first off,
Frayed wire connections or rats nest's cause quite a few problems,
Check your positive terminal post for bad corrosion or faulty connections. If you are running after market subs or amps try dissconecting temporarily because your bettery may not be able to crank out enought power, and your alternator most likely can't keep up, check your ground cable for any damage,
If you have ever boosted the car OR removed the battery with internal display on you may have overloaded the system and in that case your screwed.
Im not too familiar with seat
but I hope this helps you figure it out. good luck
Oct 04, 2009 | Car Audio & Video
Sony XAV-601BT Logo
15 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
