Question about Dyson DC31 Bagless Handheld Vacuum
Motor don't run
Doesn't run
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
Craftsman 179220 Canister Wet/Dry Vacuum
Maybe open the motor casing and look for an overheat reset button. If it doesn't have one, check for voltage at the wires coming directly out of the motor. If it has power there and no reset switch, then the motor needs replaced or rebuilt.
Jul 18, 2012 | Vacuums
Indicator light comes on but sweeper doesn't run.
it sounds like the motor is dead. The Light and the motor are wired differently so it is quite possible that the motor is dead and the light still works.
Jun 06, 2012 | Kirby Heritage II Vacuum
Start button doesn't work
test the switch.
see the diagram below. God bless you
if the switch is o.k 2) test for continuity the wires 3) Test the motor input voltage motor. 4) Test the power cord for break or loose wires with VOM
May 24, 2012 | iRobot Roomba 530 Robotic Vacuum
The motorhead on my dc05 doesn't work.
Hi David,
I'm sorry to hear you're having difficulties with your DC05 Motorhead. I'd encourage you to give our customer Helpline a call on 0800 298 0298. One of our advisors will be happy to run through some troubleshooting checks over the phone with you to help determine the cause of this issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 14, 2012 | Dyson DC05 Bagless Canister Cyclonic...
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Dyson DC31 Bagless Handheld Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
