Question about Aftermarket Vehicle Parts & Accessories
Manual for toyota allex
Servicing
My 2002 toyota fielder, the engine check light stay on and the engine turns up by itself up 2000rpm, I change and try so many things and the problem remains the same
ecu has fault codes ..needs a diagnostic scanner
could be the idle control solenoid
or something under the hood needs checking
this engine has variable valve timing
this can give trouble also
its an import to your country
Toyota Corolla/Fielder/Runx/Allex ...
on my side of the world its closest to an odessy
vvti mirvic motor
May 02, 2016 | Toyota Cars & Trucks
Toyota allex
The name Allex is a variant of the name Alex, and is Greek and it means defending. - See more at: http://www.spobd2.com/wholesale/ford-vcm-ii-diagnostic-tool-la-segunda-eneracion.html
Sep 24, 2013 | Cars & Trucks
What does p/s sign means on the toyota allex dashboard?
power steering, check your power steering fluid level.
Feb 28, 2013 | Toyota RAV4 Cars & Trucks
Which car has 1nz engine
Thie engine was used in the following form in the following vehicles:-
1.5 L (1497 cm³) Applications:
[edit]2NZ-FE 1.3 L
Applications:
[edit]
Feb 22, 2011 | 1996 Toyota Corolla
Automatic transmission Toyota Corolla 2001 Service Manual
You caneithergo to our manual section and catch a link or go to cummins shop manual.com, or cummins on line.
Mar 12, 2010 | 2000 Toyota Corolla
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Aftermarket Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Aftermarket Vehicle Part and Accessory Expert? Answer questions, earn points and help others
