Question about Euro-Flex Monster 1200 Handheld Steam Cleaner
Cannot turn steam off
Starts spraying when machine gets hot without pushing button
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
I have a Saeco Armonia Espresso Machine. The water pump was running when the tank ran out of water and when I refilled the tank, it wouldn't start again. I unpugged it and turned everything off overnight....
Common on Armonia...
There is no water in the system, so the pump is pumping air!!
you have to push on the usual button but make sure the hot water button (for tea for ex) on the right side (same as steam opening valve) of the machine is open. This will allow the water to re-flow through the system. Once water is coming out again, close hose, and stop water button. Once hose is closed, and you repush the water button, it will flow again through the coffee hole.
Voila
Nov 30, 2008 | Saeco Vacuums
Cleaning the bissell little green
Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
Oct 11, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1698-1
the heater is blocked wih lime scale
Aug 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Euro-Flex Monster 1200 Handheld Steam Cleaner Logo
23 people viewed this question
Top Euro-Flex Vacuums Experts
Are you an Euro-Flex Vacuum Expert? Answer questions, earn points and help others
