Question about Sony ICF-C1IP (Black) Docking Station
Deactivate the alarm
Cannot delete an alarm setting
How do you delete a facebook account?
In order to deactivate your Facebook account in temporary basis, just login into Facebook account > Go to account setting > choose General Settings > Scroll down find "Manage Account> click on edit > click Deactivate your account > define reason for leaving > click on deactivate account
But
Note : if you will to delete facebook account instead of click on deactivate account then Facebook can take 90 days to completely delete your acccount from facebook platform meanwhile that you can recover back your facebook account
facebook technical support @ 1-855-510-0444-qtlftztwl2bxr53yvfq0t42z-1-2.jpg
Feb 09, 2016 | Facebook Computers & Internet
Delete facebook permanently
Hi there!
There are two options for getting rid of your Facebook, Deactivating and permanently deleting.
Deactivating will hide your profile but some posts may still be visible and your account can be reactivated at any time. Deleting will remove your facebook information permanently and can not at any time be reactivated.
To Permanently delete your account instead of deactivating you will want to log into your account and go to this link:
Facebook
Then follow the directions to permanently delete your account.
Have a fantastic day!
Aug 22, 2014 | Facebook Social Network
Deactivate the hourly chimes in my TAKSUN TS-613A clock?
I am happy to tell you that THERE IS ANSWER:
In normal time mode press S, hold it, then then press D to activate (or press D again to deactivate) the alarm. You will see the symbol of Bell (above the seconds) appear (when alarm is activated) and the bell symbol will disappear (when the alarm is deactivated). Now if you FIRST press and hold D and then press S it will do the same thing (activate or deactivate the alarm). So D then S, or S then D will do the same thing for activation or deactivation of the alarm. BUT, IF YOU HEAR A BEEP (chime) SOUND when you activate or deactivate the alarm, then you actually ALSO ACTIVATED THE HOURLY CHIME!
BUT if you DO NOT HEAR THE BEEP (chime) when you activate or deactivate the alarm, then the Hourly Chime is OFF!
So (in normal time mode) try it both ways: first holding D and then pressing S, or first holding S and then pressing D (one of these will activate or deactivate the alarm WITHOUT MAKING A BEEP (chime) sound - USE THAT SEQUENCE TO DEACTIVATE THE HOURLY CHIME.
I hope this is helpful!
Mar 18, 2014 | Health & Beauty
Samsung gt c3312 alamr at 12 midnight . how to deactivate
my Samsung gt-C3312 phone has alarming at 12.00 AM and 4.40 AM while phone alarm deactivate. however, I reset master setting.
Feb 26, 2013 | Samsung GT-C3312 Cellphone - Unlocked...
Just bought a 2004 hyundai Santa Fe. Trying to learn how to set the alarm. Can someone help me please?
PRESS THE REMOTE TRANSMITTER UNLOCK BUTTON ONE TIME DEACTIVATES ALARM AND UNLOCKS THE DRIVERS DOOR ONLY. PRESSING THE REMOTE TRANSMITTER TWICE DEACTIVATES ALARM AND UNLOCKS ALL DOORS.
Feb 01, 2011 | 2004 Hyundai Santa Fe
I cant find the manual so I dont remember how to set the weekday alarm. Also can you show a picture of what the display should look like when the alarm is set? Or describe it? Thank you.
Press the Alarm button. The weekday alarm symbol will appear. Then press and hold the Alarm button for 2 seconds to enter the set mode (the hour will blink). Use the up/down buttons to choose the hour for the alarm (note the A.M./P.M. if in 12 hour mode). Press Alarm again and the minute will blink. Again use the up/down arrows to set the desired time. Press Alarm once more to exit the set mode.
To activate or deactivate the alarm, press the Alarm button until the weekday alarm icon appears. Then use the up/down arrows to activate or deactivate the alarm. When the alarm is set and active, the time will show. If the alarm has been deactivated, then dashes will appear instead of the time.
The single alarm is set and checked similarly.
I hope this helps.
(I suspect that the weekday alarm icon continues to display when the alarm is active.)
Aug 25, 2010 | SkyScan 31983 Clock Radio
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
How do i deactivate the alarm on my samsung f480. i have tried to turn it off but it just turns itself back on
To deactivate an alarm:-
1. In idle mode, tap 'Menu' then tap 'Alarms'.
2. Tap the alarm you wish to deactivate.
3. Tap again to enter the alarm settings.
3. Tap 'Alarm activation' to highlight, then tap again to select to 'Off'
4. Tap 'Save'.
Aug 16, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Sony ICF-C1IP (Black) Docking Station Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
