Question about Olympus Pen Mini 12.3MP Micro 4/3 Digital E-pm1 - Olympus
Not powering up
When I press the on button the camera does not power up
I have a Nikon d3300 that turns off automatically after i take a photo - can you assist
If the screen display is shutting off, that's a normal function. If the camera is entirely shutting off it might be a bad battery or a very weak battery.
Sep 28, 2016 | Nikon Cameras
I hve transfered all the photos from my Hero 16 MG disk to my PC. it is still not allowing me to take new photos and videos just indicating "Full"Unclear how to erase my disk. Any assistance you could
Here are the steps to reformat your SD card with your HERO3 camera:
  1. Power ON your camera with the SD card inserted.
  2. Press the front (Power) button repeatedly until you see the wrench icon on the camera's screen.
  3. Press the top (Shutter) button one time.
  4. Press the Power button repeatedly until you see a trashcan icon.
  5. Press the Shutter button one time to select the trashcan icon.
  6. Press the Power button until "ALL/Format" is highlighted.
  7. Press the Shutter button one time to select "ALL/Format".
  8. Press the Power button until "Yes" is highlighted.
  9. Press the Shutter button one time to select "Yes". Your camera's LED and the trashcan icon will blink to indicate that your SD card is being reformatted.
Once they stop blinking, power OFF/ON your camera, and your file counter should show 00.
Important - Take a picture. This confirms that your SD card is successfully reformatted.
Sep 19, 2014 | GoPro HERO3 White Edition Action Camera
Scroll problem
Press power button for 10 seconds for camera to shut down. Remove battery. Pres power button. Put the battery back in. Press power button again.
When after powering on, please check if there are firmware updates and update camera, preferably by physically connecting it to a computer.
Aug 22, 2014 | Samsung WB150F Smart Wi-Fi Digital Camera...
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Sony Cyber-shot DSC-T7. Pressing Menu button does not access any menu. Can only access Image Size menu by pressing Image Size/Delete button.
I'm sorry that the Menu button on the Camera is not working. Please try a power resetting and check the operation:
To perform the power resetting, remove the battery, press and hold the power button for more than 5 seconds and then reinsert the battery.
If the issue persists after resetting, service may be required. Please click hear to locate your nearest service facility.
Thanks for understanding. Please let me know if you require further assistance.
Jun 19, 2011 | Sony DSC-T7 Digital Camera
My backflip is locked and i forgot my blur info , how do I reset/unlock my phone ?
  1. Power off the phone, press and hold camera button ( do not release), press power button until phone turns on.Release power button while holding camera button down.
  2. Release the camera button when prompted (following the Batwings boot screen).
  3. Press the volume down button and wait for 15 seconds for a "triangle !" to appear on the screen. ( message "volume up key pressed " will appear )
  4. With flip closed, tap bottom right corner of darkened display (just above back button).
  5. Select "wipe data / factory reset" on screen
  6. Press "Ok". Wait for "data wipe complete" message to appear
  7. Press "reboot system now"
  8. Press "Ok" . Phone will reboot and complete master reset function
Notes:
Dec 05, 2010 | Motorola Mobility Backflip Smartphone
When I push the power button the lense moves in and out several times then the camera just turns off. I tried charging the battery and holding the power button down for 10 sec. but still does the same...
The power button has two purposes explanable;
1. A firm press and hold would shut down the entire device, where would be common feature for the camera to perform a system check to include the lense functionalilty.
2. A gentle press and release of the same power button should capture a snap shot only after the camera has been powered on, by the similar process as pressing firmly the power button
Remember
Pressing firmly the power button would shut down camera completely after a system check if only the camera was on.
Pressing firmly the power button when the camera is off would turn on the device by performing a system check also.
Important note
The camera when powered on would have an indicator light of ready to capture snap shots.
The camera would autoshut down when left on for an extensive duration without capturing snaps.
The instance of such would generate a camera check once more before powering off completely
The lense adds to the cameras feature capabilities of acquiring images. a function of the lense is capture an impressive image where the mechanism of drawing closer to the object is made possible by a moveable lense. The Olympus FE-340 Digital camera is powered by a battery requiring sufficient energy for a snap shot. keep in mind that, the camera can perform without the lense. However, the device is designed to automatically responded whenever the lense is required.
Important note;
1 a solution to the camera is with the source of energy in which instance batter power.
2.Dislogde the entire power area consisting of battery, check for improper installation; reinstall the battery in appropaitely noticing the installation indications of power supply. Cover the battery compartment properly, and charger afterwords.
Caution
1.Charge the battery for the entire duration known of a full charge.
2.Unplug thereafter when the full charge indicator is visible.
3.Try on the device for improvement in situation by taking photo snap shots
Dec 02, 2010 | Olympus FE-340 Digital Camera
How do you change the Date Time Stamp in the GoPro Hero series of cameras?
Taken from manual:
SETTING THE TIME AND DATE
You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
removed the time and date settings will be lost:
Symbol on LCD Screen Function
When you see "dAt" on the screen, press SHUTTER button to set the
time and date.
Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 01 (January) to 12 (December).
Press POWER/MODE button to toggle from d01 (1st day of month) to d31
(31st day of month). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
(11 p.m. military time). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
minutes). Press SHUTTER to advance to next date setting.
1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
for the settings menu.
EXITING THE SETTINGS MENU
When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
Good Luck
Thanks for using FixYa
Nov 19, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Olympus Pen Mini 12.3MP Micro 4/3 Digital E-pm1 - Olympus Logo
13 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
